Thread: Heads Up Display
Results 1 to 20 of 25
  1. #1 Re: Heads Up Display
    You can get around the volume issue by wiring the RCA preamp outputs to the speaker leads. It sounds SO MUCH better that way as well.
  2. #2 Re: Heads Up Display
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Quote Originally Posted by notladstyle View Post
    I know I tried that but I can't remember why I didn't keep it that way. It might have been the sound because I put in aftermarket speakers also.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: Heads Up Display
    Quote Originally Posted by Andrew_99GTP View Post
    true, I know the bose amp doesn't get along with after market speakers very well.
  4. #4 Re: Heads Up Display
    SE Level Member shamb1s's Avatar
    Rapid City, SD
    andrew how exactly did you go about replacing your stock head unit with a bose system?
  5. #5 Re: Heads Up Display
    New Salem, ND
    I went and bought the HU I wanted and then bought a nice 4 channel amp. I also removed all the rear speakers and installed a nice set of 6x9's. It was a personal choice because I plan to get rid of all the bose equipment in my car. I then wired in the HU like you normally would. Then wired in the amp to the HU like you normally would. Then in the trunk where the bose amp is I found the wires that go from the bose amp to the speakers and wired those wires to my new amp using the 4 channels of the amp to control the 4 corners of the car. I still have the wireing diagram that tells you which wires are what in the connectors at the bose amp. Also there is a remote wire that goes the the bose amp. I used that wire for the remote on my new amp, I just had to wire it in behind the HU. If that doesn't make sense let me know and I will try to explain it a little better.
    But if you plan on leaving the bose speakers in the care I would splice in some RCA's and wire it up that way. I did try it this way but since I was getting rid of the bose amp the way I did it made more sense.
    If you do it with the spliced RCA's it is much easier. I just spliced in some RCA ends on to the speaker wires behind the HU and plugged them into the RCA ports on the back of the HU. Either way let me know if you need more help, it has been awhile since I did mine but I will help you the best I can. Hope you found something useful in that mess I just typed
  6. #6 Re: Heads Up Display
    Rapid City, SD
    Thanks that helped out a lot, i have a pretty good idea of what i need to do to get this working. Do you remember what adapter harness you used to plug the after market HU into the vehicle harness, I really don't want to start cutting my factory harness up. Another Question I have is did you loose RAP and the chimes the way you did it?
  7. #7 Re: Heads Up Display
    New Salem, ND
    RAP and other chimes? I guess I don't know what you are talking about. I used the pigtail connector for the HU and a pigtail connector for GM wireing harnesses. This is what I used to plug into the car harness. Not saying you have to get it from there, I just used that as an example.
    ZZ Performance
    Then you should get one that plugs into the HU. I believe it comes with the HU.
  1. Stock HU display.
    By WhiteGT in forum Audio, Security & Visual Electronics
    Last Post: 10-03-2008, 02:47 PM
  2. gtp cylinder heads
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 06:29 AM
  3. heads for a gt
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-06-2008, 11:21 PM
  4. display flashing
    By Chleby in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2008, 04:43 PM
