whiney
No on the kenwoods, the rca's should always be putting out power. The menu thing that the last poster was referring to is, you can turn the internal amplifer in the deck on or off depending if you are using it or not. as for the problem, switch the rca's around and see if you have a bad set. That's about all that I can think of at the moment.
