Thread: Digital DIC Flashing Zeros
Results 1 to 12 of 12
  1. #1 Digital DIC Flashing Zeros
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I just completed putting my 97 digital DIC into my 97 SE. Using the diagram from the howto thread, I connected everything up. Made a couple of changes because wire length, but I used wiring diagrams to ensure they were connected to the right places. I took A-1 to RAD-10 and B-3 to C2-E. Everything lights up correctly and the TRAC OFF button works properly. The Low Trac even lights up when I go over some rough terrain. Only problem is, all the data items are coming up with flashing zeros. Searching through the threads there are two suggestions as to the cause:
    1.) The A-4 connection isn't hooked up to the C1-F connector. Well, mine is.
    2.) The PCM is in program mode.
    So my question is, if it is my PCM in program mode, how do I get it out of program mode? If not, what else could it be?
  2. #2 Re: Digital DIC Flashing Zeros
    does the DIC have tire pressure on it? If not, its not a 97.
  3. #3 Re: Digital DIC Flashing Zeros
    Lakeside Park, KY
    It does have the tire pressure and is indeed a 97. Truth be told, I've examined both the 97 and others thoroughly. The only difference I could see is the light is not installed and the cover sheet doesn't have the "check tire pressure" lettering on it. The functionality still looks to be there. GM just removed the wire to A4, the light and the lettering.
  4. #4 Re: Digital DIC Flashing Zeros
    i assume your PCM is stock?
  5. #5 Re: Digital DIC Flashing Zeros
    Lakeside Park, KY
    You are correct sir.
  6. #6 Re: Digital DIC Flashing Zeros
    Lakeside Park, KY
    Getting really tired of the blinking zeros!!!!!
  7. #7 Re: Digital DIC Flashing Zeros
    Lakeside Park, KY
    Ideas anyone?
  8. #8 Re: Digital DIC Flashing Zeros
    Dec 2008
    Lawndale, CA
    Recommend you check the wiring again per the diagram in the how to section. That diagram has been proven to be correct. The DIC could also be bad or the connection to the OBD connector is not good.
  9. #9 Re: Digital DIC Flashing Zeros
    Lakeside Park, KY
    Well, I used 18-22 splice connectors for the splicing. I'm going to remove them and try twisting two together using some butt end connectors.
  10. #10 Re: Digital DIC Flashing Zeros
    Dec 2008
    Lawndale, CA
    I have done two DIC's for myself and my brother. I soldered both. I have not had any issues with them two.
  11. #11 Re: Digital DIC Flashing Zeros
    Lakeside Park, KY
    Well, looks like I had a bad DIC. Found another one and put it in and now it works. Also installed my HUD. Yaaaayyyyy
  12. #12 Re: Digital DIC Flashing Zeros
    Sweet deal!
    Just in time too... lol
  1. Will a digital heater control work in a car without the digital?
    By Roanokegprix in forum General Tech Discussion
    Last Post: 11-05-2010, 08:04 AM
  2. Abs flashing
    By GTPJAY in forum Brakes/Suspension/Chassis
    Last Post: 04-16-2010, 10:50 AM
  3. DIC flashing zero
    By matt5112 in forum General Tech Discussion
    Last Post: 12-07-2009, 01:39 PM
  4. Flashing the PCM
    By Freebeer187 in forum General Tech Discussion
    Last Post: 07-22-2008, 10:47 PM
  5. 97-03 Digital DIC & Digital HVAC Swap Question
    By StreetChariot in forum General Tech Discussion
    Last Post: 03-27-2008, 11:04 AM
