I just completed putting my 97 digital DIC into my 97 SE. Using the diagram from the howto thread, I connected everything up. Made a couple of changes because wire length, but I used wiring diagrams to ensure they were connected to the right places. I took A-1 to RAD-10 and B-3 to C2-E. Everything lights up correctly and the TRAC OFF button works properly. The Low Trac even lights up when I go over some rough terrain. Only problem is, all the data items are coming up with flashing zeros. Searching through the threads there are two suggestions as to the cause:
1.) The A-4 connection isn't hooked up to the C1-F connector. Well, mine is.
2.) The PCM is in program mode.
So my question is, if it is my PCM in program mode, how do I get it out of program mode? If not, what else could it be?
