Thread: Installed aftermarket radio, now no interior lights
Results 1 to 14 of 14
  1. #1 Installed aftermarket radio, now no interior lights
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    I just installed an aftermarket radio in my car, and now none of my dash/steering wheel/window control lights work. Everything is functional, and my dome light and floor lighting work, including all the warning lights on my dash all work fine, but the speedo/tach, hvac, steering wheel, shifter, and door control illumination lights don't work. I'm assuming it's just a fuse or something, but does anyone know which one. I saw "steering wheel illumination" but I wouldn't think a 2 amp fuse would run all that. Does the orange illumination wire on the radio harness have to be wired to something? I can provide a pic to show if you need.
    2006 Mitsubishi Evo IX MR
  2. #2 Re: Installed aftermarket radio, now no interior lights
    Charles City, IA
    Did you use a factory harness adapter when you put it in?
    SMGPFC Two Nipple General
  3. #3 Re: Installed aftermarket radio, now no interior lights
    Poland, Ohio
    yes
  4. #4 Re: Installed aftermarket radio, now no interior lights
    Charles City, IA
    Thank god. I would just check all the fuses in the fuse box first. Power probes are very handy.
  5. #5 Re: Installed aftermarket radio, now no interior lights
    Poland, Ohio
    also my dic and the lights for it still work. I checked all the fuses, the seem to be fine. I didn't use a power probe, so I'll try that tomorrow.
  6. #6 Re: Installed aftermarket radio, now no interior lights
    Charles City, IA
    Check for power in and power out at each fuse.
  7. #7 Re: Installed aftermarket radio, now no interior lights
    Poland, Ohio
    Pic to show what's happening
    It's not fun driving home at night without being able to see how fast I'm going.
  8. #8 Re: Installed aftermarket radio, now no interior lights
    SE Level Member iceman977th's Avatar
    KY
    Stupid question, but did you make sure your light dimmer is set properly? I thought I screwed something up once, but it turned out it was just the dimmer fader turned down.
    2001 Grand Prix GT Sedan Silver :: Sony CD-GT54UIW :: Clarion EQS746
    2x Audioque SDC2.5 12" D4 + Audiopipe AP1500.1D :: 4 cu ft @ 32Hz, 1500w @ 1ohm
    Crescendo CCX65 Doors :: Pioneer 6x9 Rear :: Cadence CRS-Z9 4ch
  9. #9 Re: Installed aftermarket radio, now no interior lights
    Poland, Ohio
    I figured it out, the orange illumination wire was grounding. Needed to tape it better
  10. #10 Re: Installed aftermarket radio, now no interior lights
    Feb 2010
    middle o nowhere,PA
    stupid thread jack here but you have a gtp in the pic u posted and a cobalt ss in the sig..w/ one is ur car? if both..i kinda hate u haha
    02 cavalier LS sport,2.2 ecotech,5spd manual,intake,aftermarket muffler,SS style carbon fiber hood,front lip,1 3/4" drop.
  11. #11 Re: Installed aftermarket radio, now no interior lights
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Quote Originally Posted by Dragonblaze View Post
    Read his signature it clearly states he owns both
    Lol it said it right under the picture in his signature
  12. #12 Re: Installed aftermarket radio, now no interior lights
    Poland, Ohio
    Ya I've got both, and the grand prix is a gt not a gtp, although I with it was a gtp. Couldn't find one in my price range with low enough miles.
  13. #13 Re: Installed aftermarket radio, now no interior lights
    seems you need to practice better splicing techniques.
    If you're lazy you can wrap each wire separately then wrap them all so at least it doesn't look as messy and gives you a bit more protection.
  14. #14 Re: Installed aftermarket radio, now no interior lights
    Poland, Ohio
    it was more like I forgot to tape of the end of an unused wire. I didn't think it would give me any real trouble like that, plus I didn't have any electrical tape around at the time. Learn for your mistakes I guess. No big deal anyway, problem solved with no harm done.
  1. DIC not working after aftermarket radio install
    By rage03usa in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2011, 10:39 PM
  2. '98 Pontiac Grand Prix Aftermarket Radio Help
    By jetscrazy44 in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2010, 11:54 PM
  3. Aftermarket Radio Question
    By antbanks2286 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2010, 02:25 PM
  4. interior lights very dim,shutting radio off.please help
    By dvandemark in forum General Tech Discussion
    Last Post: 12-06-2009, 05:06 PM
  5. Aftermarket PCM Installed
    By Murman in forum General Tech Discussion
    Last Post: 06-05-2009, 12:28 PM
