Thread: HID conversion
Results 1 to 20 of 23
  1. #1 Re: HID conversion
    Banned
    Mansfield, Ohio
    Quote Originally Posted by rcranium View Post
    Thanks for the info.
    So I buy that kit and order clear lenses .When installed does all this fit inside my stock headlight lens cover?
    Do you have any issue with your daylight running lights? Does it interfere with your hi / low beam?
    You don't have to spend $50 on the clear lenses however if you do you'll get more color flicker at the cutoff.
    They will fit in the stock housings, I emailed retrofitsource.com and they said they will mount with no cutting of the housing. However I'd mount them with nuts, bolts, and lock washers.
    Pull the pgm mall fuse and follow the steps to disable the headlights flashing when you lock the car from your key fob. The DRL can be disabled by pulling the fuse!
  2. #2 Re: HID conversion
    Dec 2010
    earth
    Thank you.
  1. conversion?
    By 02gtp40 in forum Visual/Body Modifications
    Last Post: 06-13-2010, 12:08 AM
  2. HID Conversion...which should I get??
    By machinegunsquid in forum Visual/Body Modifications
    Last Post: 05-09-2010, 05:10 PM
  3. HID conversion kit?
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 04-03-2010, 05:19 PM
  4. HID conversion kit
    By Haulero in forum General Tech Discussion
    Last Post: 03-29-2010, 09:03 PM
  5. gt conversion to s/c
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2008, 10:52 PM
