Thread: wiring help
Results 1 to 8 of 8
  1. #1 Re: wiring help
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Well it is kinda jimmy rigged I guess you could say. I don't know about the G6 fuses but if they are like any new car they use mini fuses so you would have to go to the local car parts store or an electrical store and buy some Well it is kinda jimmy rigged I guess you could say. I don't know about the G6 fuses but if they are like any new car they use mini fuses so you would have to go to the local car parts store or an electrical store and buy some blade connectors. Then you will cut the male end so that the connector part of this is smaller so that it will fit into the fuse holder. If you need pics of this part let me know and I can go to my car and get what I am talking about and take a picture of it. For the ground it is more practical to get a ring terminal because then the whole of it will fit into the screw and fit securely between the screw and the frame.
    Oh ya I should mention that even though it is Jimmy rigged you can still feel confident in it because I did this and my Dad approved of it. (Dad has been an electrician for almost 34 years so it is hard to get his approval on a job.)
  2. #2 Re: wiring help
    Canada
    ill look into it when i get the LEDs, i think i got it now, the ground is no problem.
    as for the LED strip i just need a 12v source and a ground correct?
  1. wiring help
    By grandprixxx94 in forum General Tech Discussion
    Last Post: 09-24-2010, 11:00 AM
  2. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
  3. Please help!! EGR wiring
    By Red97GPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 11:30 AM
  4. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  5. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
