Thread: lil audio question..not a noob but need info
Results 1 to 4 of 4
  1. #1 Re: lil audio question..not a noob but need info
    SE Level Member iceman977th's Avatar
    KY
    Quote Originally Posted by Dragonblaze View Post
    ok well ive been into car audio for close to 4 years now and know enough to install most things and can fairly well adjust my amps..but i have a question that me and my friend whos been into it way longer disagree on as i wanna buy a bigger amp(1000-1500), but right now i have a crunch g2150 600watt 2ch amp powering my 2 12" hifonics brutus dvc subs that are 600rms/watts each.
    And my friend says the amp is puttin out 600 watts rms(so 300 per sub) but i disagreed cuz ik that the # on the amp is almost never what its puttin out.so i looked up its specs and the rms rating on that amp is 150-500watts not 600 but the amp does say 600watts when wired to a 4ohm load which my subs are so am i right or is my friend??
    Also,how big of an amp would i need to run the full 600 rms to each sub,i was thinking that id need a an amp puttin out 1200rms but idk. as i am doing a new set up in the achieva cuz well the bass i get from the one functioning stock 6x9 is sooooo awsome but i think my subs can do better ..so my plan was to run the 4x6s in the doors off my jvc deck,run the 6x9s im gonna use off the old mtx 400watt 4ch amp that i have and then run my subs off the crunch 600watt 2 ch amp till i can aquire a bigger amp(i loved how they sounded with the 1400 i had on em b4 the damn thing died )..all powered by 0 gauge from the battery to a distribution block on my box then 4 gauge to the amps and this same set up for the ground.
    any suggestions are welcome because well..i still dunno 1/4 of what i prolly shpould bout this stuff
    If your Crunch is 2ch, chances are it won't put out 600w RMS. Give us a budget and some more specs (RMS/peak, ohms per coil, how they're wired, etc.
    If they're dual 4's and you're on a budget, my current suggestion would be the Audiopipe AP1500.1D, 1500w RMS at 1 ohm. If your subs are anything other than dual 4's, let us know with a budget & we'll help you out somehow.
    2001 Grand Prix GT Sedan Silver :: Sony CD-GT54UIW :: Clarion EQS746
    2x Audioque SDC2.5 12" D4 + Audiopipe AP1500.1D :: 4 cu ft @ 32Hz, 1500w @ 1ohm
    Crescendo CCX65 Doors :: Pioneer 6x9 Rear :: Cadence CRS-Z9 4ch
  2. #2 Re: lil audio question..not a noob but need info
    Feb 2010
    middle o nowhere,PA
    Quote Originally Posted by iceman977th View Post
    yeah its a 2ch and they are 600rms/1200peak,2ohm i believe but they made my sub in 2 and 4 and i cant remember what mine are
    , ik they are DVC though and honestly i frgt what ohm load i have it wired for,its been a while since i had them out of the box i'll def check that tmrw though and as for budget,id say id prefere not to spend over 25-300,i love my audio but not enough to drop huge amounts of $ in to it
    02 cavalier LS sport,2.2 ecotech,5spd manual,intake,aftermarket muffler,SS style carbon fiber hood,front lip,1 3/4" drop.
  1. audio noob with some questions.
    By Kizorm in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2010, 04:11 PM
  2. noob question....
    By OhsoKleaN in forum Tires & Wheels
    Last Post: 02-08-2010, 02:32 PM
  3. noob to car audio set me straight
    By 02blackgpgt in forum Audio, Security & Visual Electronics
    Last Post: 05-30-2009, 11:04 PM
  4. Aftermarket Audio + New Cars = noob
    By juggernaut56 in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2009, 09:10 AM
  5. Idiotic noob looking for help with noobness about car audio
    By Autio in forum Audio, Security & Visual Electronics
    Last Post: 11-19-2008, 01:08 AM
