Thread: Fog lights not working
Results 1 to 20 of 27
GAFF Fog lights not working 12-02-2010, 03:58 PM
stlunatics2oo3 Re: Fog lights not working 12-02-2010, 04:32 PM
machinegunsquid Re: Fog lights not working 12-02-2010, 05:13 PM
GAFF Re: Fog lights not working 12-03-2010, 09:25 PM
TheOtherNick Re: Fog lights not working 12-03-2010, 09:32 PM
presser Re: Fog lights not working 12-03-2010, 11:30 PM
GAFF Re: Fog lights not working 12-04-2010, 02:03 PM
GAFF Re: Fog lights not working 12-05-2010, 04:05 AM
shawngtp Re: Fog lights not working 12-05-2010, 09:26 AM
GAFF Re: Fog lights not working 12-05-2010, 02:17 PM
Tommyp2010 Re: Fog lights not working 12-05-2010, 05:49 PM
GAFF Re: Fog lights not working 12-05-2010, 06:44 PM
TheOtherNick Re: Fog lights not working 12-05-2010, 06:48 PM
GAFF Re: Fog lights not working 12-05-2010, 07:41 PM
matt5112 Re: Fog lights not working 12-05-2010, 08:02 PM
TheOtherNick Re: Fog lights not working 12-05-2010, 08:03 PM
machinegunsquid Re: Fog lights not working 12-05-2010, 08:05 PM
matt5112 Re: Fog lights not working 12-05-2010, 08:08 PM
GAFF Re: Fog lights not working 12-05-2010, 08:30 PM
matt5112 Re: Fog lights not working 12-05-2010, 08:31 PM
GAFF Re: Fog lights not working 12-05-2010, 09:10 PM
shawngtp Re: Fog lights not working 12-05-2010, 09:11 PM
GAFF Re: Fog lights not working 12-05-2010, 09:15 PM
GAFF Re: Fog lights not working 12-06-2010, 03:15 PM
GAFF Re: Fog lights not working 12-11-2010, 03:08 PM
matt5112 Re: Fog lights not working 12-11-2010, 10:21 PM
GAFF Re: Fog lights not working 12-12-2010, 01:59 PM
  1. #1 Fog lights not working
    Kansas
    I have HIDs in my stock fog housing. Both quit working at the exact same time. Can anyone help diagnose the problem?
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Fog lights not working
    SE Level Member stlunatics2oo3's Avatar
    Michigan
    check fuses?
  3. #3 Re: Fog lights not working
    Florida
    I dont think there are any inline fuses on HID's..but there should be a Fog-light fuse either under the dash, or under the hood..check to see if there is, and if its blown, that could do it.
    If you have a relay harness, the relay may have gone bad...
    Check all your connections, then double check, because it'd be weird for both bulbs/ballasts to go bad at the exact same time..
  4. #4 Re: Fog lights not working
    Kansas
    I think its the fuse under the hood. Its a big ass one so what do i do go to a dealership or do auto parts stores carry them
  5. #5 Re: Fog lights not working
    Charles City, IA
    Auto parts stores carry them its called a maxi fuse.
    SMGPFC Two Nipple General
  6. #6 Re: Fog lights not working
    SE Level Member presser's Avatar
    cinci, oh & sterling hgts, mi
    mine quit working a few months ago, cleaned up the relay ground and put some electric grease stuff from autozone on it and they work ever since. I know it's frustrating but a lot of the times its the ground. got a low washer fluid warning and fixed that by finding the ground and cleaning it...it happens man. definitely check the fuse but if that's good then next look at connections and grounds
  7. #7 Re: Fog lights not working
    Kansas
    Ok i have no relay harness's. The bulbs look fine everything is still connected. It has to be the fuse since they happened at the exact same time. Im going to try and get out of bed and get something productive done on my car this weekend.
    thanks 01 for the maxi fuse enlightenment.
  8. #8 Re: Fog lights not working
    Kansas
    Didnt fix it...
  9. #9 Re: Fog lights not working
    Nov 2009
    Grand haven
    switch one of your fog light ballast with one of your headlight ballast. Just to see if you ***** slapped both of your fog light ballast's
  10. #10 Re: Fog lights not working
    Kansas
    Ill prob try that. Just to cold lol. But yea the ballast dont scream like the use to when i turn them on so i know its the connection or the ballast.
  11. #11 Re: Fog lights not working
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    Quote Originally Posted by Gafford44 View Post
    probably burned out connections. That'll happen when you don't use a relay harness.
    2006 Mitsubishi Evo IX MR
  12. #12 Re: Fog lights not working
    Kansas
    Its the 10a fuse in the engine fuse box. Replaced it after taking everything apart cleaning putting back together. Wouldn't work with the stock bulbs so knew it was a fuse. Then i realized the fuse that i missed before.
    But now I replace the fuse and it blows again after like 3 sec.
  13. #13 Re: Fog lights not working
    Charles City, IA
    You need a relay then.
  14. #14 Re: Fog lights not working
    Kansas
    So buy the HID relays?
  15. #15 Re: Fog lights not working
    Pretty much, probably best to just make your own though.
    parts stores have lighting relays on the cheap.
  16. #16 Re: Fog lights not working
    Charles City, IA
    You can make your own for like $10.
  17. #17 Re: Fog lights not working
    Florida
    My fog lights did that once I put the HID's in. Checked everything, turned out to the be fuse, so I replaced it, and it never blew again...guess it was just an old/faulty fuse...
  18. #18 Re: Fog lights not working
    fuses do wear but i have 55 watt halogen fogs and they ran fine on stock wiring and fusing.
    Installed a relay and redid all the wiring because one side would go on and off due to bad ground.
    Brighter now.
  19. #19 Re: Fog lights not working
    Kansas
    Well like i said. replaced the fuse it blew 3 times. So either my wiring is bad. Although i just redid it all, or i need something to help it.. ie relay. But I have had these fogs for over a year and first time having a problem.
  20. #20 Re: Fog lights not working
    short
  1. Shifter Lights not working ?
    By yzf125 in forum General Tech Discussion
    Last Post: 11-27-2011, 04:10 PM
  2. Interior lights not working
    By jmanrta in forum General Tech Discussion
    Last Post: 11-30-2010, 12:37 PM
  3. Brake Lights not working
    By cwhiteboy in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2010, 07:58 AM
  4. dim lights not working, bright lights ok
    By madmex2k in forum General Tech Discussion
    Last Post: 12-07-2009, 11:27 PM
  5. Fog/Driving lights not working
    By trailshredder in forum General Tech Discussion
    Last Post: 03-06-2009, 03:15 AM
