Thread: Stock Head Unit, new setup?
Results 1 to 2 of 2
RobGTP Stock Head Unit, new setup? 11-16-2010, 03:33 PM
rainmkr2 Re: Stock Head Unit, new... 11-16-2010, 05:13 PM
  1. #1 Stock Head Unit, new setup?
    SE Level Member RobGTP's Avatar
    Jul 2010
    Massachusetts
    Right now i have the 6 speaker system with the head unit that has the 7 band equalizer thing on my 2000 GTP, its not Bose or anything. I was curious what i could do to have a better setup without changing my head unit, i dont like the look of an aftermarket head unit. Could i switch out the stock 6x9's with some higher quality ones, then change out the speakers in the door too, and run an amp to them or something like that? I know a little about audio, but not a ton.
  2. #2 Re: Stock Head Unit, new setup?
    SE Level Member rainmkr2's Avatar
    UpState, NY
    Wow, this is a tough one. Speakers are always a good place to start, but the stock GM head units are tough to deal with. If your back speakers are just the 2 6x9's that is a great place to start. If you have the 6x9's and the 6.5 (round) speakers then the 6x9 are like mini subs and adding full range 6x9's will not do much.
    Even though you don't have a Monsoon system here is a post I wrote that talks about The Bass Eq Problem with GM Head units.
    Hope this helps, and for what it is worth I ended up gutting my 1998 GTP and starting from scratch. I'm trying desperately not to do the same thing with my GXP.
    Pontiac - RIP 2009!!
    1998 - GTP - Winter
    2006 - GXP - Sping/Fall
    1991 - TA DropTop - Summer
  1. stock head unit with subs and ipod hookup?
    By macey43 in forum Audio, Security & Visual Electronics
    Last Post: 07-21-2010, 09:50 PM
  2. how do you hook up subs with stock head unit?
    By peej1108 in forum Audio, Security & Visual Electronics
    Last Post: 05-30-2009, 04:57 AM
  3. can i keep stock head unit.?
    By pontiacgp759 in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2009, 01:59 PM
  4. Stock Head Unit
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2009, 07:42 PM
  5. stock head unit
    By Mikefisher in forum Audio, Security & Visual Electronics
    Last Post: 10-26-2008, 07:57 AM
