you will loose your steering wheel controls for sure
you will need a security bypass module to make the head unit work, those are couple hundred dollars
carpet on both sides will need to be pulled up for wires
power cable from battery to trunk needs to be run
there is more to this install then you think
be easier to get a car with a better stereo
