Thread: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
Results 1 to 9 of 9
Louie3 JHBHIBHIGV Rear Speakers wont... 10-16-2010, 04:29 PM
biggt Re: JHBHIBHIGV Rear Speakers... 10-16-2010, 04:35 PM
Louie3 Re: JHBHIBHIGV Rear Speakers... 10-16-2010, 04:58 PM
machinegunsquid Re: JHBHIBHIGV Rear Speakers... 10-16-2010, 05:58 PM
Louie3 Re: JHBHIBHIGV Rear Speakers... 10-16-2010, 06:20 PM
machinegunsquid Re: JHBHIBHIGV Rear Speakers... 10-16-2010, 07:43 PM
BOOSTED GP Re: JHBHIBHIGV Rear Speakers... 10-25-2010, 08:32 PM
matt5112 Re: JHBHIBHIGV Rear Speakers... 10-25-2010, 09:16 PM
nik12937 Re: JHBHIBHIGV Rear Speakers... 10-25-2010, 09:48 PM
  1. #1 JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    GT Level Member Louie3's Avatar
    Laguna Vista
    how the hell do I remove the rear deck speakers of my 05 GTP!!!! I have been trying for about an hour and can not get them out. I cant figure out how to remove the rear carpet thing that has the speaker grills!
    help!!!!!
    ZZP PCM, Wbody PCM, Custom PCM ( the best ), Headers, 3" exhaust, 3.4" pulley, ZZP 10.3 Wires, AL 104's, 160 tstat, 1.9 Rockers, Custom huge cone intake. Gunna push this GTP to the limit.
  2. #2 Re: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    did you remove the back seat atleast?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  3. #3 Re: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    Laguna Vista
    Wtf I gotta remove the back seats! F that lol I usually do my own stuff. I guess I'm going to take it some where to get done
  4. #4 Re: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    Florida
    wow...I hope removing the rear seat isnt too much of a deal for you...XD
    It honestly takes about 10minutes to get the speakers out. Remove the seats, and remove the rear deck cover, and bam, there your speakers are.
  5. #5 Re: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    Laguna Vista
    I just don't wanna break anything. How do you get the rear seats out?
  6. #6 Re: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    Florida
    Im not sure if they are the same as in the 97-03, but you should feel 2 little tabs under the actual seat (part you sit on, around where your knees are.) It should lift out, and then there are 2 nuts you remove and the back section on the seat lifts off.
    Then there are 3 of those push pins, just use a screwdriver to pry them out (careful to not break anything) and then the deck cover lifts off.
    Again not sure if its the same, but if you just look around you should see how it all goes together.
  7. #7 Re: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    streamwood
    just to clairify there are actually 4 nuts for the back seat well at least on my 97. 2 of them hold the seat belts in.
  8. #8 Re: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    my 02 has two bolts and two nuts? 18 MM head.
  9. #9 Re: JHBHIBHIGV Rear Speakers wont come out!!!!!!!!!!!!!
    Pennsylvania, USA
    On my 05 GT you have to fold down the seats, remove the 4 bolts, and then look for a retaining clip, one on each side, behind the bolster (the plastic part that was secured with the bolts).Then remove the trim pillar, then take off the rear deck cover and undo the two clips holding each speaker bracket in.
    After that it's pretty self explanatory
    Removing any speakers on newer GP's seems like a hassle, but probably well worth it, if only I had the money to get new speakers ):
  1. Rear Speakers
    By 40thannPaul in forum Audio, Security & Visual Electronics
    Last Post: 05-19-2011, 11:31 AM
  2. GTP rear speakers
    By xsvtank in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2010, 05:18 PM
  3. DIC and Rear Speakers
    By mvp828 in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2010, 12:29 PM
  4. Rear speakers
    By Farmboy87 in forum Audio, Security & Visual Electronics
    Last Post: 07-19-2009, 10:09 AM
  5. Rear speakers cut out??
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 09-16-2008, 09:53 PM
