Thread: speakers blown?
Results 1 to 16 of 16
  1. #1 speakers blown?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    i've got a kenwood excelon 794 and alpine type s 5s and 6x9s. the speakers are probably 6 or 7 years old and the headunit less than one. no amp/crossovers/RCAs in use currently, everything is hooked up through the factory harness.
    my problem - when i turn my volume up past 60% or so, i will get a blown speaker type of effect to all four and then they all get MUCH softer, nearly inaudible with a little fuzz. are my speakers blown? what else could be the cause?
    the headunit:
    RMS Power Output 22 watts
    Peak Output 50 watts
    RMS Power Bandwidth 20-20kHz
    Preamp Outputs 6-channel
    Sub Preamp Outputs Yes
    Switchable Rear Preamp Outputs No
    Preamp Voltage 4 volts
    5s
    Sensitivity 92 dB at 1 watt
    Frequency Response 45 - 30k Hz
    RMS Power Range (Watts) 2-35
    Peak Power Handling (Watts) 175
    Impedance (Ohms) 4
    6x9s
    Frequency Response 30 - 30k Hz
    RMS Power Range (Watts) 2-50
    Peak Power Handling (Watts) 250
    Impedance (Ohms) 4
    i am by no means educated in audio. i know how to hook stuff up, but that's about the extent of it. what do you think?
  2. #2 Re: speakers blown?
    did this just start happening or what?
    and what sort of music are you listening to when this happens?
  3. #3 Re: speakers blown?
    Michigan
    it's been going on for quite some time now.
    my volume controls are from 0-35. rock is about all i listen to, and anywhere over 22 they won't last for more than a minute or so. mellow rap is good to about 25 consistently.
  4. #4 Re: speakers blown?
    sounds like it might be your head unit.
    if you still have your stock one i'd swap that back in and see if the issue goes away.
  5. #5 Re: speakers blown?
    Michigan
    i swapped in the stock deck thinking that may be it, and same thing. sorry i forgot to mention that. i've messed with my EQ settings as well, reducing the lower bands and it increased the volume capacity before 'blowing' from 20 to 22. these are the only things i have tried thus far.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  6. #6 Re: speakers blown?
    Michigan
    anyone think my speakers are blown/fubar?
    logical guesses?
    97 GT - slow, rusty
  7. #7 Re: speakers blown?
    Michigan
    i can't believe noone has any input.
    chaches.
    97 GT - slow, rusty
  8. #8 Re: speakers blown?
    Feb 2009
    Virginia
    hrmmm. You said no CROSSOVERS?!
    What about the ones the Type S speakers came with? I wonder if they just have some inline filters glued to the basket? hrmm.
    If you don't have any passive crossovers on the speakers, that's why they sound blown.
    11 is louder than 10!
  9. #9 Re: speakers blown?
    Michigan
    by no crossovers, i mean none of the little box-type crossovers AFAIK.
    if i took pictures, how could i do so in order for you to tell? what should i look at?
    97 GT - slow, rusty
  10. #10 Re: speakers blown?
    Akron Ohio
    Sounds like blown speakers. Just replace them. New ones will sound better.
  11. #11 Re: speakers blown?
    Feb 2009
    Virginia
    Quote Originally Posted by noreasonwhyy View Post
    Well I found this image...
    Alpine Type S SPS-600C 6 1/2 TYPE-S COMPONENT SET [SPS-600c] - $70.00 : Fresh-Fitted.com, Brand Fashions for Less
    It looks like the filters are placed in-line on the speaker wire they provide. You MUST use this speaker wire if that's the case. Although some car companies use in-line speaker filters(cross over points), I doubt your vehicle did. So if you hooked up to stock wiring, this might be why your speakers blew.
    You'll have to double check and be certain. Pretty much all mid-range speakers are going to blow with a 30hz signal. That's where your sub should come in. Try using those filters prior/speaker wire prior to buying new speakers. Trying to play those lower freq's can muddy up the sound in a big way. Maybe they aren't blown?
  12. #12 Re: speakers blown?
    Michigan
    i've got a whole load of homework to get done in the next few days, but i will look into it.
    thanks for the info! i will post any updates when i get there.
    97 GT - slow, rusty
  13. #13 Re: speakers blown?
    Michigan
    well i got some time to mess with it. my HU has a built in crossover. after tweaking the settings, i finally have loud sounds! this is the first time my car radio is fully functioning since i've owned the GP.
    1800collect, you have any tips as to what frequencies I should put through the fronts/backs? i appreciate your help a lot!
    97 GT - slow, rusty
  14. #14 Re: speakers blown?
    Feb 2009
    Virginia
    I would suggest a High Pass around 120hz w/12db slope. You can probably get away with 100hz@24db or 80hz@24db even. If you can find a nice sub to compliment your mids then all the bass will "seem" to come from your mids up front.
  15. #15 Re: speakers blown?
    100? try 50 Hz for now.
    That wont take out too much bass at all yet clean the sound up for sure.
  16. #16 Re: speakers blown?
    Michigan
    i'm at 80hz in the front and 60 in the back, for now.
    appreciate the help.
    97 GT - slow, rusty
  1. Blown 04 gtp
    By 91z in forum General Tech Discussion
    Last Post: 08-08-2010, 09:52 AM
  2. Blown 3.8
    By Viperkill97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2010, 03:59 PM
  3. blown from car wash
    By 02gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2010, 10:10 PM
  4. I think i'm going to get blown...
    By Tig in forum Off Topic Discussion
    Last Post: 03-29-2008, 09:03 PM
