Thread: Tapping power from Amp.
Results 1 to 9 of 9
  1. #1 Tapping power from Amp.
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    My friend has a subwoofer setup with two 10" kickers and a 1000 watt amp. He had a small LED strip we wanted to put over the subs.
    We couldnt find a suitable power source and we only wanted the lights on when the amp is on, so is it okay to use the remote wire going to the radio as the positive wire for the LED strip?
    The strip has super low power-consumption so would this cause any problems?
    Thanks,
    -Ryan
  2. #2 Re: Tapping power from Amp.
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    No, do not use the remote on your amp. its not a 12 volt supply and will fry out the remote trace in your radio and amp. quit being lazy and run a suitable ignition source back.
    2008 Grand Prix + Kenwood KVT815DVD, Kicker SXRC Controller, Kicker SX 1250.1, Kicker (2) 12" L7's, Kicker SX 900.4, Kicker RS65.2 Components in front. Infinity Refs 9623i 6X9's in rear
  3. #3 Re: Tapping power from Amp.
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    running something as small as that will not hurt running it off the remote. I have run numerous neons and fans at the same time off the remote w/o any issues.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  4. #4 Re: Tapping power from Amp.
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by JCG's-GTP View Post
    ^^^ i agree
    02 GTP with mods 05 GP for DD
  5. #5 Re: Tapping power from Amp.
    Manitoba Canada
    I'd relay it off the remote and 12+ at the amp.
  6. #6 Re: Tapping power from Amp.
    Barksdale AFB, LA
    Quote Originally Posted by SofaKingCdn View Post
    This is the right way to do it...
    2009 Subaru Impreza WRX STI
  7. #7 Re: Tapping power from Amp.
    Jul 2008
    BFE, Kentucky
    I figured hayden was just being a douche but since i just let it slide. The LED strip doesn't even light all the LED's at once because it does a "zig-zag" effect so it only has one LED being powered at any given time. Also has a 12V resistor soldered in so its not hurting anything.
    Thanks :P
  8. #8 Re: Tapping power from Amp.
    Manitoba Canada
    The 200-300 MILLI amps that your deck puts out is just enough to open the relay on your amp. If you need a little more nutrience in the slow cooker and don't wanna run a relay, hook it to your trunk light so when you pop it, bling bling.
  9. #9 Re: Tapping power from Amp.
    Jul 2008
    BFE, Kentucky
    Thanks sofa. IDK why i didnt even think of hooking it to the trunk light...
  1. Without power again
    By Rocket468 in forum Off Topic Discussion
    Last Post: 04-21-2011, 12:50 AM
  2. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  3. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
  4. SC "tapping" noise... HELP!!
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2008, 05:30 PM
  5. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
