The RAP circuit turns off after 8-12 minutes. Not worth the work to disable the feature IMO... If your battery can't run the radio for 8 minutes, you have more pressing problems.
If you still feel the need to do so, the RAP circuit is a function of the BCM. You can simply unplug the RAP relay. IIRC, it is located to the right and behind the glove box.
