Thread: obdii port
Results 1 to 4 of 4
  1. #1 obdii port
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    true or false it gets its power from the cigar liter?
    If so did I totally f it up by using the cigar liter as the power source for an e-cutout?
  2. #2 Re: obdii port
    Charles City, IA
    Yeah it runs on the same fuse. You should be fine depending where you tapped for power.
    SMGPFC Two Nipple General
  3. #3 Re: obdii port
    Dec 2010
    Ohio
    yea I found the fuse fixed it the code was 137 O2 SENSOR CIRCUIT LOW VOLTS (BANK1 SENSOR 2)
    ANY IDEA?
  4. #4 Re: obdii port
    Dec 2010
    Ohio
    someone can go ahead and delete this thread I got it all fixed : )
  1. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  2. Obdii?
    By Viper in forum General Tech Discussion
    Last Post: 03-06-2010, 09:58 AM
  3. ECM To OBDII Connection
    By lstexan in forum General Tech Discussion
    Last Post: 02-07-2010, 03:05 PM
  4. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
