Thread: (2008 GP) Stick Shift light is out??
Results 1 to 5 of 5
  1. #1 (2008 GP) Stick Shift light is out??
    el paso
    you know where is has to tell you what gear your in... Well the light is just out anybody know what might be the cause and how to fix it ? i did change my stereo a while back you think that might of had somthing to do with it??
    any help thanks
  2. #2 Re: (2008 GP) Stick Shift light is out??
    swift current,sask.
    The one in the gauge cluster or the one by the shifter?
  3. #3 Re: (2008 GP) Stick Shift light is out??
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    Funny, they post a question, it's their first post and never respond to it so that we can try to help them out. If the light is out that lights up the PRND Letters on the center console below the Gear Shifter then that is a 194 bulb that has burned out. You have to take off the entire center console from the car, replace the bulb and then put the center console back on.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  4. #4 Re: (2008 GP) Stick Shift light is out??
    SE Level Member goldcrown61's Avatar
    Indiana
    Your reply will certainly help me out. I have the same issue with my 2008 GP. The only problem I'm having trouble getting the center console off. I removed 4 bolts at the bottom but it still won't come off. It's like there are some clips still holding it on but I'm afraid to pry on it for fear of snapping the plastic. Any suggestions?
  5. #5 Re: (2008 GP) Stick Shift light is out??
    Ontario
    How do I replace gear shift bulb in 2008 Pontiac grand prix? Thankyou
    David
  1. 98 GTP Performance Shift light
    By GTPkid in forum Audio, Security & Visual Electronics
    Last Post: 08-08-2010, 09:55 AM
  2. Performance Shift Light
    By stein2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 11:34 AM
  3. How to turn off daytime running light on 2008 GP
    By timc in forum General Tech Discussion
    Last Post: 02-06-2009, 01:51 PM
  4. PERF SHIFT light?
    By RichCresci in forum General Tech Discussion
    Last Post: 07-21-2008, 08:35 PM
  5. performance shift light bulb
    By prostreet in forum Off Topic Discussion
    Last Post: 03-12-2008, 09:29 PM
