Thread: HUD 2000 GTP more off than on
Results 1 to 3 of 3
  1. #1 HUD 2000 GTP more off than on
    PCMO
    Having problems with the HUD on a 200 GTP.
    Most of the time it is not visible but it seems a big temp change will cause it to work for a few minutes.
    When visible, the dimmer and height adjuster work fine.
    Thanks
    K
  2. #2 Re: HUD 2000 GTP more off than on
    PCMO
    Finally got up the courage to fix the HUD. Took about 30 min. most of that was removing and installing hud dash panel. See following link for fix.
    was a bit scared to cause damage during solder, I used solder flux on points which cleaned the contacts and made the solder flow easy.
    2000 GTP HUD Help!!
  3. #3 Re: HUD 2000 GTP more off than on
    Hurst, TX (DFW)
    The cold solder trick works almost everytime. Just need to be careful when taken off the trim piece and soldering is a breeze if you have a decent gun.
  1. New guy here 2000 gp gt
    By LON323 in forum Introductions/Noob Questions
    Last Post: 07-24-2010, 04:52 PM
  2. My car....2000 gtp
    By QUICKSILVER462 in forum Visual/Body Modifications
    Last Post: 06-04-2009, 04:48 PM
  3. 2000 se
    By evilpacker in forum Visual/Body Modifications
    Last Post: 07-18-2008, 08:10 PM
