Thread: my trip computer/dic doesnt work !?!?
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: my trip computer/dic doesnt work !?!?
    Willoughby, Ohio
    loose connection
  2. #22 Re: my trip computer/dic doesnt work !?!?
    Feb 2010
    middle o nowhere,PA
    Quote Originally Posted by jetscrazy44 View Post
    i took off the dash panel and moved some wires around, so now it works idk but thank god
    wish mine worked like that -_-...that blinking 0.0 i see every day is startin to piss me off and id like it to work b4 i drive to pa in this thing.
  3. #23 Re: my trip computer/dic doesnt work !?!?
    Feb 2010
    O'Fallon MO
    Mine has been doing this for the last 6 months. I've subscribed to 5 different threads about this. No one knows how to fix it or what's causing the problem. Ive replaced all wheel sensors, my PCM, my DIC. My speed sensor. Everything I can think of.
    98GTP : Mods:Gen V Swap, SRI, Intense Tuned PCM w/ Polycarbon PCM Trey, Autolight 1 Step Colder Plugs, Ported and Wrapped Manifolds, 180*Tstat.
    96Ws6 : 2000 Ls1 Swap, Texas Speed True Duels, Kooks Headers, 98+ Conversion(Front end, Taillights)
  4. #24 Re: my trip computer/dic doesnt work !?!?
    Willoughby, Ohio
    ^^^then it could be a wiring issue
  5. #25 Re: my trip computer/dic doesnt work !?!?
    Feb 2010
    O'Fallon MO
    Brake control module?
  6. #26 Re: my trip computer/dic doesnt work !?!?
    Feb 2010
    O'Fallon MO
    Wirings good, checked it all unfortunately.
  7. #27 Re: my trip computer/dic doesnt work !?!?
    GT Level Member 40th GP's Avatar
    Utah
    Anyone find a solution to this? I am the new owner of a 40th anniversary (first post), and my info center display is intermittent. When I test drove the car it worked fine, but then after the transaction there was no lights on the display on the way home. Then a few days later it was on again, and now it has not been back on since. Like others I have read around the forum I have looked at it and it just the right light you can see that the numbers are changing, I guess indicating that the unit is working, there is just no light to it. The button backlights all seem to be working, but the display itself is not illuminated. Is this just an issue of bulbs? That seems odd since it randomly came back on that one time. I also called the previous owner and they said that it had been intermittent in the past as well. Any other ideas, or has anyone found a solution?
  8. #28 Re: my trip computer/dic doesnt work !?!?
    Oct 2012
    philly
    old thread but I'll give it a shot.
    I am having similar problem. Mine would blink out then come back on. Started to do it more frequently as time went on. Then I noticed it would go out when I turned my heater blower on. After a day or so I am having a hard time getting the blower motor on unless I put it on HI. Any ideas?
  9. #29 Re: my trip computer/dic doesnt work !?!?
    Utah
    Quote Originally Posted by vicsponjr View Post
    Sounds more like an ignition switch issue.
  10. #30 Re: my trip computer/dic doesnt work !?!?
    Oct 2012
    philly
    Ordered a new ignition switch. Figures it would go in the winter :/
  11. #31 Re: my trip computer/dic doesnt work !?!?
    Oct 2012
    philly
    Sparky's Answers had detailed instructions for install. Everything working again
  1. Power comes & goes to trip computer/HVAC
    By fmp3 in forum General Tech Discussion
    Last Post: 10-19-2014, 05:53 PM
  2. Help! My horn doesnt work...
    By 97gtpprix in forum Audio, Security & Visual Electronics
    Last Post: 08-18-2010, 04:08 PM
  3. 01 trip computer problems
    By kpeck3193 in forum Audio, Security & Visual Electronics
    Last Post: 02-10-2010, 08:37 PM
  4. Radio doesnt work!! Please help!!!
    By Bigbm80 in forum Audio, Security & Visual Electronics
    Last Post: 12-13-2009, 11:43 PM
  5. Trip computer
    By SCGTP in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 06:52 PM
