Thread: 15" sub
Results 1 to 20 of 23
  1. #1 Re: 15" sub
    GT Level Member MrPhotographer06's Avatar
    Fort Bragg, NC
    Well these are plans for the future. I'm basically gonna put about 400 into it. I've got the supplies, and help for the box, if I can get some dimensions.
  2. #2 Re: 15" sub
    Destroys cars izup69's Avatar
    Iowa
    I have 2 s12l7 kickers in my car (them being square they have the same surface area as a round 15 inch sub) They rattle my car apart. Anyway id say a box volume of at least 2.5 cubic feet PER SUB enclosed. My l7's are in a very small bandpass box (1.32 cubic feet) and it sux. If you are looking for sound quality and just not all out db go with a enclosed if your looking for all out db go with ported or bandpass box tuned for your subs. I think the enclosed boxes are a richer sound. I also hate the sound of all the air rushing out of ported/bandpass boxes. Thats my view tho some might disagree with me. As for amps you get what you pay for if u buy a cheap amp it will be a pile of $h!t. I got a cheap amp for my subs and it was rated at 1700rms@2ohm mono class D amp. So I figured it was pushing about 90% of its rated rms watts which is 1530 rms. My subs are 750rms each and I know they are not hitting anywhere near as hard as they can. The more money u have the better sounding system you will have.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
