Thread: Amp Went into Protect Mode
Results 1 to 13 of 13
PTGsDaytona500GTP Amp Went into Protect Mode 08-22-2010, 06:23 PM
matt5112 Re: Amp Went into Protect Mode 08-22-2010, 08:42 PM
mriley Re: Amp Went into Protect Mode 08-23-2010, 07:16 PM
mriley Re: Amp Went into Protect Mode 08-23-2010, 07:17 PM
josemolina2008 Re: Amp Went into Protect Mode 08-24-2010, 12:22 AM
christopher8911 Re: Amp Went into Protect Mode 08-24-2010, 10:02 AM
BillBoost37 Re: Amp Went into Protect Mode 08-24-2010, 10:23 AM
PTGsDaytona500GTP Re: Amp Went into Protect Mode 08-26-2010, 05:17 PM
I800C0LLECT Re: Amp Went into Protect Mode 08-26-2010, 09:23 PM
PTGsDaytona500GTP Re: Amp Went into Protect Mode 08-27-2010, 03:55 PM
Ricky21 Re: Amp Went into Protect Mode 08-26-2010, 10:59 PM
timmysgtp Re: Amp Went into Protect Mode 08-27-2010, 04:03 PM
matt5112 Re: Amp Went into Protect Mode 08-27-2010, 04:07 PM
  1. #1 Amp Went into Protect Mode
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    I was driving the other day and randomly my amp went into protect mode and no I didn't hit a bump. I then turned off my car and back on and it came back on then 5 minutes later off again and no it wasn't overheated. Now it stays in protect mode. Since I turned my car off and back on and my amp came back on it makes me believe there is nothin wrong with my amp and my subs are not blown either. So any suggestion appreciate it.
  2. #2 Re: Amp Went into Protect Mode
    you wired your subs too low for your amp?
  3. #3 Re: Amp Went into Protect Mode
    SE Level Member mriley's Avatar
    Jun 2010
    enfield ct
    its the speaker wire try replacing the speaker wire. if not than it has to do with dc signals and all this other junk i dont know much about
  4. #4 Re: Amp Went into Protect Mode
    Jun 2010
    enfield ct
    if you have the manual read that. or google it, same thing happened to me but i was too lazy so i have about 1300 dollars of car audio sitting in my garage because of the stupid amps i got pissed and took everything out
  5. #5 Re: Amp Went into Protect Mode
    GT Level Member josemolina2008's Avatar
    Modesto, Ca.
    Are you 100% sure your subs aren't blown? I had this same problem and I "knew" my subs weren't blown until we looked closer and one was blown. Also does it cut out when you have it really loud or just randomly happens at any volume.
    GP is gone...
  6. #6 Re: Amp Went into Protect Mode
    SE Level Member christopher8911's Avatar
    North Carolina
    Make shure you have your amp wired correctly. You can use a ohmsmeter to check if the speakers are blown.
  7. #7 Re: Amp Went into Protect Mode
    If this isn't a new install or something wasn'tly recently added (check there first) then something is bad.
  8. #8 Re: Amp Went into Protect Mode
    Jul 2010
    Broadview Hts Ohio
    Thx for all the advice but it turned out my amp just took a s*** Good thing my brother has like three amps so i am going to just buy it Thx again guys
  9. #9 Re: Amp Went into Protect Mode
    Feb 2009
    Virginia
    If that's true a capacitor blew or it was wired wrong and the "bump" was a coincidence. Make sure you load the next amp properly. DB-R electronics or ZED Audio will fix the other amp. If it's a cap that went bad it won't cost much.
    11 is louder than 10!
  10. #10 Re: Amp Went into Protect Mode
    Jul 2010
    Broadview Hts Ohio
    Quote Originally Posted by I800C0LLECT View Post
    Well my system was beatin' for a while so maybe a capacitor blew how much is that?
  11. #11 Re: Amp Went into Protect Mode
    Minnesota
    That happened to me and a few buddies we all thought the amp was blown, id say double check and make sure its grounded very well, if thats a no go either one of your subs may be blown or in my case the wire inside the box on the speaker was disconnected, hooked it back up and the beats were beating again
  12. #12 Re: Amp Went into Protect Mode
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    always check rca cables they go bad often!!! I did autosound for a living for few years.. Also if you have dvc speakers you can have one coil in one speaker go bad and it will cause your amp to go in protect
  13. #13 Re: Amp Went into Protect Mode
    There are many types of caps used in an amp so no one could tell you since it varries based on whats in there and what you want to replace it with quality wise.
  1. What causes limp mode?
    By GTP4 in forum PCM Tuning
    Last Post: 07-20-2010, 12:22 PM
  2. Limp mode
    By dragrace351 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2010, 12:32 AM
  3. Performance shift mode on 05+
    By GrandprixGearhead in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:15 PM
  4. abuse mode?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 05:32 PM
  5. performance mode?
    By CMURDAx in forum General Tech Discussion
    Last Post: 08-09-2009, 10:01 AM
