Thread: Radio Aux input Jack Install (How To)
Results 1 to 4 of 4
  1. #1 Radio Aux input Jack Install (How To)
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    I'm pretty busy until this weekend being classes have started again. I'll be doing a writeup later that shows how I did this. There's no need for a tape deck or external cd changer. I bought about $70 worth of electronics to figure this out so hopefully some of you would donate if you find this write-up useful. This install would cost less than $10 if you already have a solder gun/solder and a multi-meter. The sound is perfect and there is no static if done right. The treble/bass work as well as the equilizer
    Uploaded with ImageShack.us
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  2. #2 Re: Radio Aux input Jack Install (How To)
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    cool!
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  3. #3 Re: Radio Aux input Jack Install (How To)
    Dunmore
    You definitely got deep into that project, thats awesome. I have a 2004 GTP I found a 6 disc stock head unit because there is an aftermarket unit you can buy which allows you add an aux input and utilize the steering controls. You wouldn't happen to know if your fix will work on newer units?
  4. #4 Re: Radio Aux input Jack Install (How To)
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    i was considering this myself, but the benefits of an aftermarket receiver ruled out keeping the stocker.
    nice to see it done on a GP delco, though.
  1. How to add a line input jack on 04+ with XM
    By OH4CompG in forum How To Write-Ups/Tech Tips
    Last Post: 05-28-2013, 10:55 PM
  2. opinions on xm radio install
    By RyanL in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2010, 11:35 AM
  3. 2005 radio install
    By 05grandprixgt in forum Audio, Security & Visual Electronics
    Last Post: 02-08-2010, 12:20 PM
  4. 04 Grand Prix Radio Install
    By ionroller in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2010, 03:17 PM
  5. 2006 Grand Prix CB Radio Install
    By novacoke in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2009, 10:01 AM
