Thread: Time for a new system...
Results 1 to 20 of 24
Threaded View
  1. #7 Re: Time for a new system...
    Feb 2009
    Virginia
    Modding doors is actually a lot easier than people think. The hard part is acquiring the many different skills that help with implementation
    I think Hertz has a diagram that implies you want the speakers to be aligned equidistant from your ears in a top to bottom format. Which essentially means you're installing them based on a radius. Personally, that's fine if you don't use Time Aligement. If you use t/a then I would suggest using a similar vertical axis for all 3 speakers on a single side. The distance between them won't matter too much if you have flexibility in active cross overs. Otherwise, to mitigate crossover issues keep the mid-range close to the tweeter in the A pillar. Matt's personal install would be the best choice for that. Also, since the speakers are up high, keep them on-axis. But on-axis means your designed your system for a single seat. It won't sound as good to passengers. An alternative to a similar vertical axis would be to put the mid-bass speakers in your doors. If you keep them mono you may not notice any x-over issues as long as you stay around 200hz...maybe 300hz. This will mitigate any issues using t/a on only two channels for the front. However, if you run them stereo then you'll need 4 channels w/ time alignment. A set for the mid-bass in doors and another set for the tweets and mid-ranges to run from.
    Sorry if it seems convoluted. Pick out anything from above if you want me to expound I'm sure Matt and that Carpepoon can help too.
    11 is louder than 10!
  1. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  2. Part time headlights, all the time
    By myzon26 in forum General Tech Discussion
    Last Post: 03-04-2010, 08:23 AM
  3. Installing system in 2005 GP for first time
    By stoner17971 in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 10:46 PM
  4. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  5. ABS System?
    By mcg_999 in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2008, 10:40 AM
