More detailed, so try it again
Remove key from from ignition
remove the BCM PROGRAM, from the glove box fuse box, if no BCM fuse is found remove the MALL PROGRAM fuse
close all doors
close the lift gate
insert key into ignition, and turn it to the ACC ( one click towards you in the car)
leave key in for 5 then do next step
turn key to off and back to acc with in one second
open a door and close it, A chime SHOULD be heard when the system enters program mode
press and hold the LOCK and UNLOCK for 14 seconds, after seconds a chime may be heard that will confirm program
remove key
install FUSE
