Thread: Grill Lights write ups anyone?
Results 1 to 20 of 23
  1. #1 Grill Lights write ups anyone?
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    Anybody got a write up for installing 2 grill lights such as these:
    Whelen Engineering - Lightheads - Lightheads, Directional Strobe, Super-LED
    hopefully your write up includes wiring it to the fuse box, i think that'd just be the safest for me to do in terms of draining the battery. Also i hope you have an idea for a manual switch on the inside of the car so the lights dont just turn on with the car in aux or ignition.
    Thanks
  2. #2 Re: Grill Lights write ups anyone?
    SE Level Member paulygp09's Avatar
    Minnesota
    i would splice them into your fog lights so when the fogs switch is on the led's come on too... otherwise, run a wire all the way to the fuse box and use the ciggy lighter for power and put a switch where you want it... done
    ~Pauly~
  3. #3 Re: Grill Lights write ups anyone?
    Nanuet, NY
    i like the fog light idea, but mine are switched on all the time, they have some kinda sensor in them that they only turn on in like cloudy, rainy ish kinda days. i dunno how to describe it but the switch is always in the on position but the lights are not always illuminated
  4. #4 Re: Grill Lights write ups anyone?
    Nanuet, NY
    i suppose its possible to just go around the sensor, but i have no idea where itd be located, anyone?
  5. #5 Re: Grill Lights write ups anyone?
    Minnesota
    im not to familiar with this... maybe there is a fuse that could be pulled to disable automatic lights???? just something to check i guess... i assume they are on at night so i would still just wire them with the fogs, who cares if they are on during the day they are led's.... they run for a long time!
    ~Pauly~
  6. #6 Re: Grill Lights write ups anyone?
    Nanuet, NY
    yea but the point is they cant be on while the car is in motion, and i plan to use them as courtesy lights for responding to EMS calls from home
  7. #7 Re: Grill Lights write ups anyone?
    Nanuet, NY
    rather they have to be able to go on and off in motion
  8. #8 Re: Grill Lights write ups anyone?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Hope this helps
  9. #9 Re: Grill Lights write ups anyone?
    Minnesota
    oh... forgot about that... ^^^^ do this! that was option 2
    ~Pauly~
  10. #10 Re: Grill Lights write ups anyone?
    Nanuet, NY
    lol any idea how to pop off the dashboard so i can run the wires behind it?
  11. #11 Re: Grill Lights write ups anyone?
    Nov 2009
    Quote Originally Posted by EJRJR91 View Post
    I took the plastic piece off in the foot well and ran them to the center console. and if you want to place them/route them in a certain spot you could go to target or such a place with 3M products and look for some plastic hooks that have the sticky backs to them.
  12. #12 Re: Grill Lights write ups anyone?
    Nanuet, NY
    Also what size gauge wire do you think would be necessary for these kinda lights?
  13. #13 Re: Grill Lights write ups anyone?
    Nov 2009
    It depends on how many LED's you are planning to run. In the tech specs for the product it should say how many leds and some say how much power each led takes to power it (doesnt take much). Depending on how much power you need is going to depend on the gauge but you wont need too little of a gauge considering LED's take up nearly no power at all
  14. #14 Re: Grill Lights write ups anyone?
    Nanuet, NY
    so what would u say is the smallest u could imagine me needing? just so i have like a limit to size
  15. #15 Re: Grill Lights write ups anyone?
    Nov 2009
    how many led's and what is the current needed to power each individual one?
  16. #16 Re: Grill Lights write ups anyone?
    Nanuet, NY
    not sure what the current needed is but i'm planning to have two leds, of the ones in the link above
  17. #17 Re: Grill Lights write ups anyone?
    LED's use almost zero power.
  18. #18 Re: Grill Lights write ups anyone?
    Nanuet, NY
    so i guess any gauge would really work then
  19. #19 Re: Grill Lights write ups anyone?
    Nov 2009
    I'd go with a ten amp fuse max with 16 gauge wire
    cause if they are LEDs like mine. They use 12 milliamps which is like one hundreth of an amp
  20. #20 Re: Grill Lights write ups anyone?
    Nanuet, NY
    what kinda LEDs do u have? show a pic if thats easier
  1. Grill
    By DEEGZ in forum 5.3L V8 (LS4)
    Last Post: 08-08-2010, 12:05 AM
  2. Want to buy 82-86 gprix grill
    By skysdalimit in forum Shops and Community Heroes
    Last Post: 06-25-2010, 03:47 PM
  3. Wiring LED grill lights!!! Please help
    By cojo in forum Visual/Body Modifications
    Last Post: 03-15-2009, 02:34 PM
  4. Has anyone used this grill?
    By abuckley1290 in forum Visual/Body Modifications
    Last Post: 01-11-2009, 07:10 PM
