Thread: 98 GTP Performance Shift light
Results 1 to 6 of 6
  1. #1 98 GTP Performance Shift light
    Jul 2010
    Columbiaville, MI
    my perf. shift light wont come on. ive read that these arent always hooked up? or is the bulb burned out?
    98 GTP 2DR
  2. #2 Re: 98 GTP Performance Shift light
    GTP Level Member SuperSport's Avatar
    Michigan
    Since the blue Perf Shift only appeared in the 98s dash, Does the light in the dash flash on briefly when you turn the key on? If not it may be a bad bulb.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: 98 GTP Performance Shift light
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    the light doesn't come on with the key on unless the perf shift button is pushed on, just like the high beam light. Do you notice a difference in shifting if perf shift is on?
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  4. #4 Re: 98 GTP Performance Shift light
    Wausau, WI
    it is a much bigger difference if you have a reprogrammed PCM for tranny functions. All dash lights should come on briefly when you power up the vehicle.... go and try it to see if it lights up at all when the rest of the dash lights come on.
  5. #5 Re: 98 GTP Performance Shift light
    Dec 2008
    London, Ontario
    it won't light up unless the button is pushed in on the shifter
  6. #6 Re: 98 GTP Performance Shift light
    Denver
    It takes about 10 min to pop off the dash and check the light. A new bulb is about $2.
    It was the first dash bulb of mine to burn out in my 98 so I bet it's just a bad bulb.
    I let it annoy me fr a year or so before I finally tore into it. Had I known then what I know now, I would have fixed it immediately. Taking the dash aprt is very simple and fast.
  1. Performance shift
    By djrepoman in forum General Tech Discussion
    Last Post: 03-15-2010, 12:36 PM
  2. Performance shift on used DIC
    By Joe in forum General Tech Discussion
    Last Post: 07-02-2009, 05:08 PM
  3. Performance Shift Light
    By stein2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 11:34 AM
  4. performance shift WTH?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-08-2008, 09:44 PM
  5. performance shift light bulb
    By prostreet in forum Off Topic Discussion
    Last Post: 03-12-2008, 09:29 PM
