Thread: stock head unit with subs and ipod hookup?
Results 1 to 9 of 9
macey43 stock head unit with subs and... 07-20-2010, 11:02 PM
Colossus Re: stock head unit with subs... 07-20-2010, 11:55 PM
macey43 Re: stock head unit with subs... 07-21-2010, 10:27 AM
macey43 Re: stock head unit with subs... 07-21-2010, 06:41 AM
Colossus Re: stock head unit with subs... 07-21-2010, 10:46 AM
noreasonwhyy Re: stock head unit with subs... 07-21-2010, 11:05 AM
macey43 Re: stock head unit with subs... 07-21-2010, 06:32 PM
whiney Re: stock head unit with subs... 07-21-2010, 06:47 PM
macey43 Re: stock head unit with subs... 07-21-2010, 09:50 PM
  1. #1 stock head unit with subs and ipod hookup?
    GT Level Member macey43's Avatar
    Jul 2010
    salisbury, MA
    hey i like my stock head unit... but i also want subs. I know you can hook them up with some kind of rca adaptor. Does anyone know any good writeups, or even want to explain? Also im tired of static from my radio transmitter, so while im in there is there anyway to hook a direct line up for my ipod?
    sig too tall
  2. #2 Re: stock head unit with subs and ipod hookup?
    Windsor (ON) Canada
    Do you have RCA cables coming from the back of your unit?? if so, get a Y cable...thats what Im doing.
  3. #3 Re: stock head unit with subs and ipod hookup?
    Jul 2010
    salisbury, MA
    Quote Originally Posted by Colossus View Post
    No there arent any rcas only the like 20 pin connector thingS
    sig too tall
  4. #4 Re: stock head unit with subs and ipod hookup?
    Jul 2010
    salisbury, MA
    I'm not sure but I'll check
    sig too tall
  5. #5 Re: stock head unit with subs and ipod hookup?
    Windsor (ON) Canada
    If you want to be running subs from your stock head unit, youll also need some sort of external subwoofer controller (http://www.thetechgeek.com/images/ne...os/PLXR-A8.jpg)... OBVIOUSLY do not get pyle (their garbage, just showing you what it loooks like). There are fairly cheap, and fairly nice looking decks out there that would have sub out put and AUX input for your ipod.
  6. #6 Re: stock head unit with subs and ipod hookup?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    easiest solution without taking your headunit apart: PAC makes modules that add RCAs to stock headunit, and others that allow you to create an auxiliary input.
    PAC AMP-RCA USED WITH ADD CABLE ShipSound.com
    Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
    if you go this route, be sure you get the model you need. i just did a quick search so you get the gist of things.
  7. #7 Re: stock head unit with subs and ipod hookup?
    Jul 2010
    salisbury, MA
    ok thanks everyone. so basically for the subs i need the rca adaptor then run an amp to that with the subs and everthing? oh ya and is the level control all i need for the subs? or should i get like a crossover also?
    sig too tall
  8. #8 Re: stock head unit with subs and ipod hookup?
    swift current,sask.
    Just the line level control, there should be crossover settings on your amp, use those and you will be set.
  9. #9 Re: stock head unit with subs and ipod hookup?
    Jul 2010
    salisbury, MA
    Quote Originally Posted by whiney View Post
    ok even better
    sig too tall
  1. how do you hook up subs with stock head unit?
    By peej1108 in forum Audio, Security & Visual Electronics
    Last Post: 05-30-2009, 04:57 AM
  2. can i keep stock head unit.?
    By pontiacgp759 in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2009, 01:59 PM
  3. Stock Head Unit
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2009, 07:42 PM
  4. stock head unit
    By Mikefisher in forum Audio, Security & Visual Electronics
    Last Post: 10-26-2008, 07:57 AM
