Thread: Stock headunit with MTX subs
Results 1 to 4 of 4
  1. #1 Stock headunit with MTX subs
    SE Level Member PrixGT's Avatar
    Jul 2010
    Canada
    So I'm slowly building my system, Jackhammer 10" with matching box and still undecided on amp. However, I'm using the stock head unit, for two reasons: I like the steering wheel controls, and because where I travel if they see a aftermarket HU, they steal it. I know it can be done, I'm just curious what all I need to do it, and what I do with the RCAs and yadda yadda. And also taking suggestions for an amp.
  2. #2 Re: Stock headunit with MTX subs
    Outer Space
    go to crutchfield.com and act like your gonna buy an aftermarket HU .. radio controls will work with a different HU. And use RCA's instead of a line output converter or your signal to your amp is going to suck.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Stock headunit with MTX subs
    memphis
    Get a line out converter & wire it to you rear speakers..it will allow you to use RCA's to hook your amp up...it'll work fine untill you up grade to new HU..
  4. #4 Re: Stock headunit with MTX subs
    dont buy from crutchfield, they're overpriced.
    sonicelectronix.com is pretty good.
  1. Question about stock subs
    By wildmn26 in forum Audio, Security & Visual Electronics
    Last Post: 04-07-2010, 11:31 PM
  2. Subs with stock BOSE deck
    By thumper in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2010, 10:41 PM
  3. how do you hook up subs with stock head unit?
    By peej1108 in forum Audio, Security & Visual Electronics
    Last Post: 05-30-2009, 04:57 AM
  4. Thinking of swapping out the stock headunit....
    By Y2KGTP in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2008, 11:08 PM
