Thread: Disabling light flash on lock/unlock
Results 1 to 9 of 9
  1. #1 Disabling light flash on lock/unlock
    Michigan
    Alright i'm sure this is probably posted somewhere else already but I cant seem to find a tutorial on how to make this stop. It killed my hid ballasts in 2 days and i need to find out how to disable this feature before reinstalling. Help is appreciated. thanks
  2. #2 Re: Disabling light flash on lock/unlock
    Michigan
    bump
  3. #3 Re: Disabling light flash on lock/unlock
    West Side Michigan
    Check your manual. Also you can flip on your high beams before you exit the car that way turning off the ballast.
  4. #4 Re: Disabling light flash on lock/unlock
    Michigan
    Even if the brights are on they will still flash when i lock the doors
  5. #5 Re: Disabling light flash on lock/unlock
    Dec 2008
    Lawndale, CA
    What year is you car?
  6. #6 Re: Disabling light flash on lock/unlock
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    Just found this the other day. Take out your mall PCM fuse located in the passenger side fuse box. Pull it out turn it back to the accessory position just the radio, and push the lock button. Depending on the year it might be different for you. The chime will go off a number of times, each times is a different mode. Only one chime is no flash no lights. Thanks are welcome
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  7. #7 Re: Disabling light flash on lock/unlock
    Windsor (ON) Canada
    Quote Originally Posted by ls6velless454 View Post
    Did this today, worked, but just curious, am I supposed to lose the hornk honk too?
  8. #8 Re: Disabling light flash on lock/unlock
    Its in the owners manual which you can download online for free......
  9. #9 Re: Disabling light flash on lock/unlock
    Feb 2009
    Virginia
    Hrmm. I have an 04...I believe that option is hidden in my DIC somewhere.
    11 is louder than 10!
  1. Disabling Headlight Flash for HID's
    By skidoojames151 in forum How To Write-Ups/Tech Tips
    Last Post: 06-14-2012, 12:28 PM
  2. Repeated TCC lock/unlock with no PCS readout
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2010, 11:02 AM
  3. No lock/unlock but trunk release works
    By Twelvoltz in forum Audio, Security & Visual Electronics
    Last Post: 08-15-2009, 09:26 PM
  4. Tuner Changes for TCC Lock/Unlock Issue
    By Lawngoose in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2009, 10:42 AM
  5. Increasing lock/unlock wirless strength
    By Freebeer187 in forum General Tech Discussion
    Last Post: 09-05-2008, 11:37 PM
