I800C0LLECT
If you are running an H.O. alt then there IS a benefit to big 3--assuming you ARE using that power. However, you should be aware of v-droop and amperage that the length of a cable can maintain. If I were you, I'd upgrade the wiring but get rid of a secondary battery. Unless you plan to run your system when the engine is off there's no real use for it.
