Hello All,
I'm starting the planning phase of putting some better speakers and possibly (well, most likely) an amp into my car.
It has no monsoon, no cd changer, and has Onstar, but I'm not using it.
Here's what I'm thinking of doing:
1) Keep stock CD Player - I really want to hold on to the stock look, and the chimes etc.
2) Add an AUX-IN, My car does have Onstar (not using it) and no CD player. I've got a MOTO Droid and want to be able to listen to music/audiobooks on my drive to work.
3) Get a bit better speakers (REAR), I have some Kenwood 6x9's for the back that are identical to what my wife has in her car, and I'm happy with them.
4) Get better speakers (FRONT), This is up in the air, I'm willing go with components, but am not looking to do much custom. Otherwise I'll probably go with some Infinity 6.5 coax's.
5) 4 channel amp. This one is optional I guess, but I'd like to at least put the wiring in while I have the car half torn apart. I've got an old Lanzar Optidrive 4100. Nice little amp, worked great for my buddy for a year or two before he sold his car. I'd like to use it if possible, but it does NOT have high level inputs, RCA's only.
So.. my questions:
-For the AUX-in, anyone have any recommendations?
I THINK i need the PAC-GM24, anyone else know for sure? I can take pics of the deck etc if i need too, i understand that there are some differences in them..
-Anyone have a recommended amp wiring kit? I COULD add a 10inch sub in the future, but that's unlikely. I'm betting a walmart kit would probably do fine for me, but if someone knows of a decent kit let me know!
-I'm planning on mounting the amp between the rear speakers, what are you guys using for ground points in the back?
-Are LOC's going to work OK for the speakers? Where should I mount them? Anyone have a recommendation? Walmart seems to sell them here..
- Where do you guys pull the power? up the driver or passenger side?
- Remote on for the amp? I have read this forum and found like 40 different answers to this, is there a wire in the cd harness I can tap or is there an easier one to run with the power?
- Rear deck - It's 4 bolts and yank the seat, I think I can figure that one out from forum posts.. So i don't know if I have a real question, but any advice would be great.
- Front speakers - Should I go with some components, or will that take a bunch more work? I'm thinking that the lanzar isn't a real high rms amp (25?) so it may do better with some coax. I don't want to get in the way of the window, so, which size should I use in the fronts?
Thanks for any help, I know it's a ton of questions. I've done some research, but there is so much on here it's daunting.
