use a larger bulb or a LED strip run in parallel with the back plate for the LEDs,
Here is his original project, I wanted to rewire it to work with the lower shifter and the cluster display. unfortunately I never have time to work on electronics projects any more.
http://www.backinblackgp.com/SVRS.htm
its going to be gross. It took 20 minutes to get the area clean under it, also where the seal between the spoiler and the trunk mate will probably need some wax and care.
