Thread: Will 4 Kicker 12's fit?
Results 1 to 9 of 9
  1. #1 Will 4 Kicker 12's fit?
    SE Level Member iceman977th's Avatar
    KY
    I have two '07 CompVR 12's in my car in the stock Kicker ported box right now and they're working fine, but there's a pair of '05 CompVR's someone is selling for $200, so I was thinking about getting them and doing a nice install in my car. They're all dual 2 ohm VC subs, and I'm thinking of getting new amps & new mids/highs to complement them. How big of a box would all 4 be, and i'm assuming I'd want it ported. Also, is there a way to wall them off so I can still have trunk space (for bookbag, bags, etc.) I know I'll need an electrical upgrade big time if I do too. Thanks guys.
    EDIT: Okay, I decided instead of going Memphis amps, that two kicker ZX750.1 amps will work. Each sub is dual 2 ohm, so wiring the individual sub in series, then pair them up in parallel puts them back at 2 ohms, meaning minimum 750w RMS to each pair, which is good because the RMS rating per pair is 800w RMS (400w RMS per sub). What would you guys suggest as the best speakers/amp combo for mids/highs? (Remember, 5 1/4" + tweeters in doors & 6x9's in back.
  2. #2 Re: Will 4 Kicker 12's fit?
    sounds like a bad idea.
    how about you design a system for the car instead of using what you already have? It works out better that way.
    You could wall it, but how in the hell does the sound get into the cabin? It wont. Either you leave the passthrough open or you remove your rear 6x9's and pray you dont get a terrible bandpass enclosure thing going on there.
    How would you need electrical for 1600 watts RMS if you never use it? And by electrical I mean a HO alternator.
    What is the goal here? To make some subs your going to get a "deal" on work in your car in addition to the other ones you have?
    Why not sell your old subs and get better subs?
    As for the more important 15 octaves of the 16, how are you not running into issues already?
  3. #3 Re: Will 4 Kicker 12's fit?
    Jul 2008
    sumter,south carolina
    4 12's is a lil much for my tastes... ive found that 10's sound better than 12's in a GP IMO
    02 GTP with mods 05 GP for DD
  4. #4 Re: Will 4 Kicker 12's fit?
    You mean 10's blend better than 12's with your speakers.
  5. #5 Re: Will 4 Kicker 12's fit?
    Willoughby, Ohio
    dont deal with having alotta subs and not being able to hear anything. just get 2 CVXs in a ported box and call it a day
  6. #6 Re: Will 4 Kicker 12's fit?
    get two lms-x 12's and put 'em in a sealed box and call it a day.
  7. #7 Re: Will 4 Kicker 12's fit?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    this.... if you have the money....
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  8. #8 Re: Will 4 Kicker 12's fit?
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    id go with two high end 10's. some JL's or Kickers. possible a ported box? i have to 12's and its getting to be an annoyance. im probably going to sell them and get 2 10's in a sealed box. another question what music to you listen to. rap has a deeper bass. rock seems to have a tighter bass.
    EDIT: some rap has deeper, longer bass notes.
  9. #9 Re: Will 4 Kicker 12's fit?
    Size of the sub has nothing to do with it if you actually have a REAL midbass solution and not just stock speaker replacements.
  1. need help with kicker amp
    By kyleheine298 in forum Audio, Security & Visual Electronics
    Last Post: 05-04-2010, 11:45 PM
  2. what kind of kicker is this?
    By gtpinsc in forum Audio, Security & Visual Electronics
    Last Post: 02-06-2010, 08:27 PM
  3. Kicker l7 question
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 12-25-2008, 08:46 PM
