Quote Originally Posted by ZR1Vette09 View Post
why would he get pulled over? sounds legit to me. may even be something i look into. Which kind of LED bulbs did you use? you can't see my brake lights or turn signals in the day.
They were off ebay, just ones that had diodes on the sides too.
Quote Originally Posted by oneil.GTP View Post
does the 08 take the same 3057 bulb as the 97-03s? if so, check out the following link.
Brighter 3057 bulb? - CandlePowerForums
the following is quoted from post #18 in the link above.
hope this helps, it did for me.
Thanks for the info, I'll try again and reverse them.
Quote Originally Posted by TurboTrav
the running lamp wire for the bottom brake bulbs. That way it will only light up when I hit the brakes or use a turn signal.
aka his break lights arn't on tell he hits the breaks so i assume at night they do the same thing--- you would have to hit your breaks every time a cop is behind you
It worked fine. Here is just the running lights on. Just the top now, instead of top and bottom.
