Thread: Amp error?
Results 1 to 20 of 23
  1. #1 Amp error?
    CT
    Well on my way home last week I was cruising listening to music when all of a sudden my bass stopped hitting. I look back as I have the opening in the back seat open to see my amp off. Wondering what happened when I stopped I checked and the fuses on the amp had been tripped. Now I know I did not have an inline fuse which is my fault but I had been moving things around and just never put it back on. So my amp still works but under a small load. If I try to push it the light on the amp will blink and it displays an error of E-03. I have a Kenwood 25th anniversary mono amp. Is it toast or what? I think its toast but before I replace it I'd like to find out for sure.
  2. #2 Re: Amp error?
    Willoughby, Ohio
    you need to find out what E-03 means. check the manual. this should tell you what happened to your amp
  3. #3 Re: Amp error?
    CT
    Well I did some research (I don't have the manual but located a PDF version) and found that the E-03 error has to do with a speak wires grounding out. But the thing is that it stops working when I turn up the voume and the bass hits harder.
  4. #4 Re: Amp error?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    Quote Originally Posted by dagger View Post
    i bet the speaker is blown try another one
  5. #5 Re: Amp error?
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    more power probably means better connection and more power grounding it out causing it to die. check your wires. im sure someone else would have something to say but id start by checking your set up for something simple like you drilled into a wire or something silly. just a thought best of luck keep us posted
    silver 2003 Grand Prix GT List is on it's way to be updated
  6. #6 Re: Amp error?
    Feb 2010
    ohio
    lets think about this
    he was bumpin
    bass stopped hittin
    amp was off
    fuses on amp was tripped
    can play at low volume
    shorted voice coil= blown sub!!!!!!
  7. #7 Re: Amp error?
    CT
    Both subs work though?? They both play and the amp still works its just until the whole thing really starts to hit pretty decent. I'll double check my wiring and try one sub at a time just to make sure they work correctly. Thanks I'll give those things a try either tonight or thursday night and post back whats up.
  8. #8 Re: Amp error?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    well if it didn't blow all the way as it hits more the coil move thus causing it to hit that short that could be your problem,
    i'd find a buddy with subs that take more power and hook those up and see if its the amp or sub
    also if the amp dose it on my advice i would say it melted a wire inside the amp before the fuse blew and its not touching put with the more push it grounds out
    thats IMO
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  9. #9 Re: Amp error?
    GT Level Member chickenfried's Avatar
    Feb 2010
    Gilman IA
    this kinda happened to me. check your signal wires on your subs, and the voice coils. lol just varify that for us
  10. #10 Re: Amp error?
    Willoughby, Ohio
    Quote Originally Posted by TurboTrav View Post
    thats IMO
    do this! trouble shoot! use another system to see if its the amp or subs, as in hook up your subs to another amp ans your amp to another set of subs ro whats not workin right. then go from there
    i think your amp is goin into protection mode so it wont get damaged, so its probably the subs
  11. #11 Re: Amp error?
    Cedar Rapids, IA
    Quote Originally Posted by CTKGP09 View Post
    don't put the subs on another amp if the subs are bad it might hurt the amp, (if its protection fails or has none) trade known bad for known good not the other way around
  12. #12 Re: Amp error?
    CT
    Yeah I'll pull it apart and test it. If I pull it apart fully I may just end up building a new box before it goes back in because I just hate this box so much.
  13. #13 Re: Amp error?
    Willoughby, Ohio
    well he doesnt know whats wrong so he has to start somewhere
  14. #14 Re: Amp error?
    Cedar Rapids, IA
    ya just don't want him to blow up someone else's amp
  15. #15 Re: Amp error?
    CT
    I think my first test will just be taking one set of subs off and trying one at a time to see if it does anything different. Then if that doesn't do **** I do believe a friend of mine has an old sub he's not using and won't give a **** if I blow it up anyways.
  16. #16 Re: Amp error?
    Willoughby, Ohio
    that will work as long as its a known good sub
  17. #17 Re: Amp error?
    CT
    Well finally got around to figuring out what was up with the subs. Looks like one sub went bad and I had a few other things. I rewired everything and tested it and it came up with the same error on the amp. Pulled one sub and tested and it worked fine so I got a bad sub. I made sure to test the amp to its fullest and the sub. Looks like I'll be getting a new set of subs but this time I'll get 12's as they don't sell the 10's anymore. I liked these subs and for the price its buy one get one free for $150. Oh well I guess.
  18. #18 Re: Amp error?
    Cedar Rapids, IA
    what brand of subs?
  19. #19 Re: Amp error?
    Minnesota
    blown sub im betting just happened to me and a friend. but i took one of the subs out of the box and one of the connections was disconected hooked it back up and it worked like new
  20. #20 Re: Amp error?
    CT
    Quote Originally Posted by Ricky21 View Post
    One of the connections was off but I wasn't sure if that was me or not. Its blown and right now is still in the box just not hooked up so I have some bass but not as much as I want lol.
    the subs are just like these but 10's :Kicker CompVR 07CVR124 12" subwoofer with dual 4-ohm voice coils at Crutchfield.com
    My amp is: Kenwood 25th Anniversary XXV-03A Mono subwoofer amplifier 533 watts RMS x 1 at Crutchfield.com
    I was really hoping it wasn't the amp because I couldn't find any that were close to that for a cheap price. I got 2 of the subs, that amp, a box and everything all hooked up for $300 from a friend. So far its all been great other than this happening. I'm guessing its just something that happens as I was just driving home and they just stopped.
  1. error code p0650
    By IrishNation24 in forum General Tech Discussion
    Last Post: 01-16-2010, 10:50 AM
  2. Check Gas Cap Error Message
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 01:40 PM
  3. DTC code error
    By carlos Hidalgo in forum General Tech Discussion
    Last Post: 08-11-2009, 08:35 PM
  4. Error code po742
    By RichCresci in forum General Tech Discussion
    Last Post: 11-30-2008, 09:37 PM
  5. Vb Garage Upload error
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 10-31-2008, 08:00 PM
