Thread: Amp error?
Results 1 to 20 of 23
  1. #1 Re: Amp error?
    Willoughby, Ohio
    Quote Originally Posted by TurboTrav View Post
    well if it didn't blow all the way as it hits more the coil move thus causing it to hit that short that could be your problem,
    i'd find a buddy with subs that take more power and hook those up and see if its the amp or sub
    also if the amp dose it on my advice i would say it melted a wire inside the amp before the fuse blew and its not touching put with the more push it grounds out
    thats IMO
    do this! trouble shoot! use another system to see if its the amp or subs, as in hook up your subs to another amp ans your amp to another set of subs ro whats not workin right. then go from there
    i think your amp is goin into protection mode so it wont get damaged, so its probably the subs
  2. #2 Re: Amp error?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Quote Originally Posted by CTKGP09 View Post
    don't put the subs on another amp if the subs are bad it might hurt the amp, (if its protection fails or has none) trade known bad for known good not the other way around
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  1. error code p0650
    By IrishNation24 in forum General Tech Discussion
    Last Post: 01-16-2010, 10:50 AM
  2. Check Gas Cap Error Message
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 01:40 PM
  3. DTC code error
    By carlos Hidalgo in forum General Tech Discussion
    Last Post: 08-11-2009, 08:35 PM
  4. Error code po742
    By RichCresci in forum General Tech Discussion
    Last Post: 11-30-2008, 09:37 PM
  5. Vb Garage Upload error
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 10-31-2008, 08:00 PM
