Thread: 2000 GTP factory alarm question
Results 1 to 7 of 7
ls6velless454 2000 GTP factory alarm... 04-19-2010, 09:39 PM
SliceTheRice Re: 2000 GTP factory alarm... 04-19-2010, 09:45 PM
ls6velless454 Re: 2000 GTP factory alarm... 04-19-2010, 09:47 PM
ls6velless454 Re: 2000 GTP factory alarm... 04-20-2010, 12:23 AM
ls6velless454 Re: 2000 GTP factory alarm... 04-21-2010, 11:29 AM
PCTGTP Re: 2000 GTP factory alarm... 05-19-2010, 07:28 AM
Bio248 Re: 2000 GTP factory alarm... 05-19-2010, 09:31 AM
  1. #1 2000 GTP factory alarm question
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    I have a 2000 GTP and whenever I set my car alarm there is no horn, and only the front headlight flash on just curious if this is normal? I know with some other GM's on youtube you can change this. It's just annoying not knowing that my car is locked without walking all the way around it.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  2. #2 Re: 2000 GTP factory alarm question
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Check your owner's manual. I believe that is a setting you can select. It will show you how to program the options you want.
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  3. #3 Re: 2000 GTP factory alarm question
    Nov 2009
    Portage, IN
    Unfortunately I don't have it.
  4. #4 Re: 2000 GTP factory alarm question
    Nov 2009
    Portage, IN
    Anyone else?
  5. #5 Re: 2000 GTP factory alarm question
    Nov 2009
    Portage, IN
  6. #6 Re: 2000 GTP factory alarm question
    Donating Users PCTGTP's Avatar
    Ohio
    i believe the first time you press the keyfob the lights flash for a "certain security setting," press again the horn should beep and lights flash.
  7. #7 Re: 2000 GTP factory alarm question
    you can change the settings on it so that it does or does not use the horn.
  1. Factory Alarm disabled?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2009, 03:09 PM
  2. Factory alarm for 98 GTP
    By tjvdubsport in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2009, 09:39 AM
  3. Disable Factory Alarm?
    By TheDesertFox in forum Audio, Security & Visual Electronics
    Last Post: 04-12-2009, 10:24 PM
  4. Factory wheel question
    By s10mods in forum Tires & Wheels
    Last Post: 08-23-2008, 06:57 AM
  5. Does my GP have a factory alarm?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 03-23-2008, 10:48 AM
