Thread: HELP!!! Tach doesnt work TCS stays on
Results 1 to 13 of 13
hondo HELP!!! Tach doesnt work TCS... 04-10-2010, 06:08 PM
hondo Re: HELP!!! Tach doesnt work... 04-16-2010, 02:44 PM
hourang Re: HELP!!! Tach doesnt work... 04-16-2010, 03:27 PM
hondo Re: HELP!!! Tach doesnt work... 04-16-2010, 04:23 PM
hourang Re: HELP!!! Tach doesnt work... 04-19-2010, 04:03 PM
hondo Re: HELP!!! Tach doesnt work... 04-21-2010, 08:12 PM
matt5112 Re: HELP!!! Tach doesnt work... 04-22-2010, 10:28 PM
hondo Re: HELP!!! Tach doesnt work... 04-23-2010, 08:05 AM
hourang Re: HELP!!! Tach doesnt work... 04-23-2010, 11:30 AM
shawngtp Re: HELP!!! Tach doesnt work... 04-23-2010, 08:17 AM
  1. #1 HELP!!! Tach doesnt work TCS stays on
    SE Level Member hondo's Avatar
    Salt Lake City, Utah
    Okay, so i washed my car today and the battery died because i had the doors open and it started but it took it a while. when it did i drove it to charge the battery and noticed the TCS light was on and woulnt turn off and when i touched the brake at all the tach would drop to zero and now it doesnt work at all except it will come on for like 2 seconds just jumping up and down. the car didnt throw any codes or anything so i dont know whats up with it.
    PLEASE HELP!!
  2. #2 Re: HELP!!! Tach doesnt work TCS stays on
    just an update... still doesnt work im thinking about just tearing things apart till i find it.
  3. #3 Re: HELP!!! Tach doesnt work TCS stays on
    GT Level Member hourang's Avatar
    commerce, mi
    your battery shouldnt die from having your car door open. did it take 8 hours to wash your car or something? besides the interior lights shut off automatically after 15mins i think. you most likely have a bad battery, bad alternator, or bad wiring (check grounds).
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  4. #4 Re: HELP!!! Tach doesnt work TCS stays on
    Quote Originally Posted by hourang View Post
    i had the stereo on for a few hours.
    i have looked around and the only things i can find would be a bad crank position sensor. (but the car does not stall)
    or wires are touching the A/C accumulator mounting ring. (but i dont know what that is.) so any help on either would be awesome.
  5. #5 Re: HELP!!! Tach doesnt work TCS stays on
    commerce, mi
    did you wash the motor?
    -Jeff
  6. #6 Re: HELP!!! Tach doesnt work TCS stays on
    i did wash the engine but i used barely any water. its been hesitating to start so i think its the CPS
  7. #7 Re: HELP!!! Tach doesnt work TCS stays on
    Quote Originally Posted by hondo View Post
    BINGOOOOOOOOOOOOOOOOOOOO!
  8. #8 Re: HELP!!! Tach doesnt work TCS stays on
    bingo?? what did i break then do you know now?
    that would be amazing i'm so sick of that car lol
  9. #9 Re: HELP!!! Tach doesnt work TCS stays on
    commerce, mi
    water and electronics do not mix. if you wash your motor you need to cover all the major electronics. i lost an optispark in my 94 z28 by doing that, $500 mistake (back then).
    -Jeff
  10. #10 Re: HELP!!! Tach doesnt work TCS stays on
    optisparks are apparently ****ty to start with.
    And yeah OP, new CPS required.
  11. #11 Re: HELP!!! Tach doesnt work TCS stays on
    Nov 2009
    Grand haven
    ^^^ CPS.. common problem..
  1. Brand new tranny and doesnt work right HELP
    By WM123 in forum Introductions/Noob Questions
    Last Post: 02-14-2010, 06:30 PM
  2. Radio doesnt work!! Please help!!!
    By Bigbm80 in forum Audio, Security & Visual Electronics
    Last Post: 12-13-2009, 11:43 PM
  3. Blower motor doesnt work
    By Eagle in forum General Tech Discussion
    Last Post: 09-21-2009, 07:41 AM
  4. 06 GP, cruise doesnt work, fuse good, HELP!!!
    By Schooter in forum General Tech Discussion
    Last Post: 08-13-2009, 07:56 PM
  5. Heating Doesnt Work After Engine Replacement
    By m0ng00se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-16-2008, 07:06 PM
