Thread: Grommets
Results 1 to 13 of 13
EJRJR91 Grommets 05-15-2011, 05:04 PM
dpzelenak Re: Grommets 05-15-2011, 05:07 PM
Confusingboat Re: Grommets 05-18-2011, 12:39 AM
EJRJR91 Re: Grommets 05-17-2011, 09:53 PM
TheOtherNick Re: Grommets 05-17-2011, 09:57 PM
dpzelenak Re: Grommets 05-18-2011, 04:38 AM
Confusingboat Re: Grommets 05-18-2011, 11:28 PM
98gtp Re: Grommets 05-19-2011, 07:10 AM
dagger Re: Grommets 05-18-2011, 09:59 AM
EJRJR91 Re: Grommets 05-18-2011, 07:17 PM
EJRJR91 Re: Grommets 05-19-2011, 09:50 PM
dpzelenak Re: Grommets 05-19-2011, 09:54 PM
EJRJR91 Re: Grommets 05-19-2011, 10:43 PM
  1. #1 Grommets
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    Anyone know where the grommets on the driver and passenger sides can be found and how to access them? I wanna run wires through them but i wanna know the best way to access them. Also would it be best to try nd push the wire through the grommet with whatever wires might already be in it or would it be better to create a new hole to the side of the grommet?
    I searched the forums but didn't find much on this
    2002 Pontiac Grand Prix SE --> Audio, Lighting, Exterior
  2. #2 Re: Grommets
    theres one of the pass side is behind the rear exhaust manifold and closest to the pass side, as for the wires, i took a pipe cleaner and shoved it though and then raped the wire around the other side and pulled it though, the one on the drivers side i think is behind the brake booster
    SMGPFC Member #10
  3. #3 Re: Grommets
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Lol just used that one today. Ended up removing the grommet, cutting part of the center out and just running the wire through it and putting it back in. This ****'s a pain in the ass.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  4. #4 Re: Grommets
    Nanuet, NY
    Anybody got a picture of them to make the locating easier?
  5. #5 Re: Grommets
    Charles City, IA
    Pull back the carpet on the passenger side, you will see it.
    SMGPFC Two Nipple General
  6. #6 Re: Grommets
    oh yes it was huge PITA, mainly because the grommet on the fire wall and the hole in that floor insulation pad thing, arn't lined up so the wire has to make a turn in the middle, which makes no sense to me
    i can get pics on sunday if you still need them
    SMGPFC Member #10
  7. #7 Re: Grommets
    Minnesota
    Mine was lined up....lol. P.S. the new setup sounds great. Oh. Mah. GAWD.
    2015 Evo MR
  8. #8 Re: Grommets
    Oct 2008
    Calgary, Alberta
    Are you talking about the grommet that the transmission select cable passes through? (I used this to bypass the vacuume line for the climate controller with 3/16" brake line)
  9. #9 Re: Grommets
    CT
    I know when I ran my wire the hardest part was getting that huge chunk of rubber out of the way as it was stuck in there pretty tight. As soon as that way out of the way I was able to get everything through no problem.
  10. #10 Re: Grommets
    Nanuet, NY
    i havent looked yet because its been raining so pics would be nice to see before i jump into it
  11. #11 Re: Grommets
    Nanuet, NY
    whichever one will allow me to get a wire from the glovebox area to the engine bay, and then from the engine bay back to the steering wheel
  12. #12 Re: Grommets
    the one in the pass side of the fire wall, i think i cought it in a pic i took, ill ty to find it, if not ill get some this weekend
    SMGPFC Member #10
  13. #13 Re: Grommets
    Nanuet, NY
    thanks, much appreciated for when i get the chance to go looking for it to have an idea of where it is
