Thread: Capacitors??
Results 1 to 20 of 23
  1. #1 Capacitors??
    SE Level Member GTPjunkie's Avatar
    Yorktown, VA
    Refer to my other post for application - But I am curious... how do you know which "farad" capacitor is needed for your sub and amp setup??
  2. #2 Re: Capacitors??
    Willoughby, Ohio
    usually one farad for every 500 watts RMS of power...
  3. #3 Re: Capacitors??
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    Quote Originally Posted by CTKGP09 View Post
    this is a good rule of thumb. especially for our cars which have fairly decent alternators. do the voltage upgrade too. and the big 3. and you'll be set!
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  4. #4 Re: Capacitors??
    Leightion, IA
    you can never really go wrong with oversizing on caps though... just don't go buying a 10 hybrid cap for something like 2,000 watts or less... your just crazy then... even though they do look good!
  5. #5 Re: Capacitors??
    Yorktown, VA
    True.. which amps would you suggest in that case matt?
  6. #6 Re: Capacitors??
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    caps won't help if you are getting dimming you need a HO alt
  7. #7 Re: Capacitors??
    Dec 2008
    chicago,illinois
    wouldn't doing the big 3 help with light dimming ?
    going low on 20"
  8. #8 Re: Capacitors??
    Cedar Rapids, IA
    Quote Originally Posted by windycitygtp View Post
    not without a HO alt
  9. #9 Re: Capacitors??
    swift current,sask.
    Quote Originally Posted by TurboTrav View Post
    Depends on how many amps you are pulling.
  10. #10 Re: Capacitors??
    Feb 2009
    Virginia
    Quote Originally Posted by whiney View Post
    Big 3 is trendy. It really doesn't help anything except maybe V droop unless you have higher output alts (as stated above) AND HARDWARE THAT UTILIZES SAID H.O. ALTS!
    Again, most people utilize about 15-20 watts per speaker on average when they crank. Get some equipment and do actual readings if you want proof.
    11 is louder than 10!
  11. #11 Re: Capacitors??
    Cedar Rapids, IA
    not to jack but the lowest i got yesterday was a 10.9V
  12. #12 Re: Capacitors??
    Feb 2009
    Virginia
    That could also be due poor connections or small guaged wire or LENGTH of said wire. Refer to the12volt.com to help with wire runs and determining power requirements.
    I have a 4awg run in an 04 GP with ~1800(a/b power supply) watts on tap. In cold weather(30 or below no humidity) I go down the highway with 14.9 on the DIC and ~14.5 measured in the trunk.
    Again, there's no way in hell I use that many watts. But if I run my subs incorrectly I can definitely strain the alt with dimmed lights. However, my voltage is still fine.
  13. #13 Re: Capacitors??
    swift current,sask.
    How is your deck and amp still running?? How is your alternator not dead yet????
  14. #14 Re: Capacitors??
    Wis-Compton
    How are you dropping down to 10.9 may I ask? You must have some serious malfunctions with your electrical? Last weekend I had 6K rms wired up in my car, and I didn't dip below 11.X... Fluke tested at front battery..
  15. #15 Re: Capacitors??
    MO
    i do have 1 reported case of a cap helping. one of my TEACHERS kept screwing up his alternator with subs, then put in a cap and it quit breaking. I don't think it's a good way. Just buy yourself a good name-brand amp.
    <brandonl2000> LMAO D!!
  16. #16 Re: Capacitors??
    Feb 2009
    Virginia
    Read this!! If you have a good quality amp then the caps are already built into the power supply
    Search is your friend!!!!
    http://www.grandprixforums.net/f41/u...r-24989-2.html
    http://www.grandprixforums.net/f41/o...ion-26663.html
    http://www.grandprixforums.net/searc...earchid=450710
  17. #17 Re: Capacitors??
    Nov 2008
    ohio
    caps are junk get a deep cycle battery in your trunk next to your amp..way better
    04 Grand Prix GTP (Wizaired, 3 inch downpipe)
  18. #18 Re: Capacitors??
    Feb 2009
    Virginia
    Quote Originally Posted by ionroller View Post
    That makes no sense. If you are drawing more power than the alternator creates...adding another load doesn't help that. You'd end up having to recharge that batt every so often if your power use really did dictate its use.
  19. #19 Re: Capacitors??
    GTP Level Member
    springfield IL
    caps are a WASTE of $$$!!! if your system is big enough(draws more then 100amps of current) a xtra bat will help but put strain on your alt. iv had an xtra red top(in trunk) on my factory alt for 5+ years with no light dimming when its cranked up, amp(s) are mmats dhcx2200.1's.. few years ago ive only been using 1 amp.. just this past summer my alt started goin out as my head lights and dome lights were startn to dim with the bass so i put an HO alt in. you should get an high output alt b4 getn caps!!!
  20. #20 Re: Capacitors??
    swift current,sask.
    My buddy has an m-2000 and i have an m-500, those amps are awesome and underrated!
