Refer to my other post for application - But I am curious... how do you know which "farad" capacitor is needed for your sub and amp setup??
usually one farad for every 500 watts RMS of power...
you can never really go wrong with oversizing on caps though... just don't go buying a 10 hybrid cap for something like 2,000 watts or less... your just crazy then... even though they do look good!
Big 3 is trendy. It really doesn't help anything except maybe V droop unless you have higher output alts (as stated above) AND HARDWARE THAT UTILIZES SAID H.O. ALTS!
Again, most people utilize about 15-20 watts per speaker on average when they crank. Get some equipment and do actual readings if you want proof.
That could also be due poor connections or small guaged wire or LENGTH of said wire. Refer to the12volt.com to help with wire runs and determining power requirements.
I have a 4awg run in an 04 GP with ~1800(a/b power supply) watts on tap. In cold weather(30 or below no humidity) I go down the highway with 14.9 on the DIC and ~14.5 measured in the trunk.
Again, there's no way in hell I use that many watts. But if I run my subs incorrectly I can definitely strain the alt with dimmed lights. However, my voltage is still fine.
i do have 1 reported case of a cap helping. one of my TEACHERS kept screwing up his alternator with subs, then put in a cap and it quit breaking. I don't think it's a good way. Just buy yourself a good name-brand amp.
Read this!! If you have a good quality amp then the caps are already built into the power supply
Search is your friend!!!!
http://www.grandprixforums.net/f41/u...r-24989-2.html
http://www.grandprixforums.net/f41/o...ion-26663.html
http://www.grandprixforums.net/searc...earchid=450710
caps are junk get a deep cycle battery in your trunk next to your amp..way better
caps are a WASTE of $$$!!! if your system is big enough(draws more then 100amps of current) a xtra bat will help but put strain on your alt. iv had an xtra red top(in trunk) on my factory alt for 5+ years with no light dimming when its cranked up, amp(s) are mmats dhcx2200.1's.. few years ago ive only been using 1 amp.. just this past summer my alt started goin out as my head lights and dome lights were startn to dim with the bass so i put an HO alt in. you should get an high output alt b4 getn caps!!!
My buddy has an m-2000 and i have an m-500, those amps are awesome and underrated!
