Thread: Easy way to see if I have remote keyless entry?
Results 1 to 4 of 4
  1. #1 Easy way to see if I have remote keyless entry?
    Sonoma County, CA
    Hi, everyone:
    Just got a 1995 GTP from my neighbor. He's not the original owner, but he thinks it might have had the remote keyless entry system at one point. Besides just buying a remote off of eBay and hoping for the best, is there a quick way to see if my car has keyless entry? Thanks.
  2. #2 Re: Easy way to see if I have remote keyless entry?
    Willoughby, Ohio
    maybe a security light on the dash?
  3. #3 Re: Easy way to see if I have remote keyless entry?
    SE Level Member habeba86's Avatar
    Elmwood/Peoria Ill
    If you get the vin or the other id codes you should be able to have a dealer tell you
    10 Z1000
    00 gtp..few goodies
    97 XJ
    98 T/A cammed/stalled/spray *sold*
  4. #4 Re: Easy way to see if I have remote keyless entry?
    alabama
    open your trunk and on your right side pull back the carpet on the wall find the bundle of wires that go to your taillights if it has 1 black wire with a stripe coming off of it that goes into a blank connector then you have keyless entry. this terminal is used to program new key fobs... your box is under your rear deck mat between the speakers. you have to pull the rear seat to get to it. you can also reach up through the trunk and feel the remote box through one of the holes between the speakers closer to the right or passenger one.
  1. Keyless remote entry
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2012, 03:00 PM
  2. Keyless remote entry
    Last Post: 08-04-2009, 03:33 PM
  3. Remote Keyless Entry
    By quijibo in forum Audio, Security & Visual Electronics
    Last Post: 05-21-2009, 11:58 AM
  4. Help with remote start/keyless entry
    By Red97GPGT in forum Audio, Security & Visual Electronics
    Last Post: 03-13-2009, 10:50 PM
  5. Did all 04 GP come standard with remote keyless entry
    By serenityacres in forum 04+ Specifics
    Last Post: 02-20-2009, 04:53 PM
