Thread: Grounding both amps?
Results 1 to 11 of 11
  1. #1 Grounding both amps?
    SE Level Member Magnaflow GP's Avatar
    canada
    Im wondering whether i should use a ground distribution block making both amps grounded at the same place, ive heard this isnt the best and that i should run seperate wiring from each amp to a different ground and not to use a ground distribution block. Is this true?
  2. #2 Re: Grounding both amps?
    You want to have a central grounding location so either the same spot or the same piece of metal.
    Also, keep them separate so if one fails, they don't all fail.
  3. #3 Re: Grounding both amps?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    and dont make the ground over 2-3ft will cause noise tryin keep all grounds as short as possible
  4. #4 Re: Grounding both amps?
    shorter grounds just means less chance of failure.
    nothing about noise since the ground still has to travel the length of the chassis regardless of how its wired.
  5. #5 Re: Grounding both amps?
    Feb 2010
    ohio
    ^^true matt, newer cars if the ground is to long it can cause noise, longer ground has higher resistance,compared to the distance front to back of a huge chasis, its equivalent to a hundred runs of zero guage.
  6. #6 Re: Grounding both amps?
    Only if you get a ground on the right piece of metal.
  7. #7 Re: Grounding both amps?
    canada
    thanks appreciate it ill prob run on top of the rear fender
  8. #8 Re: Grounding both amps?
    SE Level Member paulygp09's Avatar
    Minnesota
    thats where I have mine, and have no trouble with sound quality!
  9. #9 Re: Grounding both amps?
    canada
    good to know! thanks
  10. #10 Re: Grounding both amps?
    Feb 2009
    Virginia
    Noise typically results when one ground is backfeeding into another due to their measured differences. If you have two grounds that are equal then there will be no backfeed. However, trying to accomplish that in a vehicle is near impossible. Typically multiple grounding points already exist in a vehicle. You could use separate grounding points to maintain the "18 inch rule" but then that idea of cross talk between differences in grounding points could occur.
    Same thing can happen with a single ground point. Car Audio amounts to nothing more than good guess work Pick your poison. My grounds hit a block that feeds to 4awg grounding point on rear wheel well. It's about 18" in length. The biggest reason for that rule is so that your cable can carry a large load without frying.
    Remember...the difference between grounding points could even cause back feed through RCA's. That's why EQ's traditionally add noise to signals. This is why people prefer digital as much as possible too. I believe balanced and digital are over kill in a vehicle environment.
    11 is louder than 10!
  11. #11 Re: Grounding both amps?
    Quote Originally Posted by I800C0LLECT View Post
    Road noise trumps it most of the time.
  1. How are your amps mounted?
    By archemedes in forum Audio, Security & Visual Electronics
    Last Post: 10-10-2009, 08:49 PM
  2. Amps?
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2009, 12:01 PM
  3. subs and amps
    By edp in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2008, 04:22 AM
  4. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
