Thread: Audio Wiring Tricks?
Results 1 to 7 of 7
  1. #1 Audio Wiring Tricks?
    Donating Users LuckyBambu's Avatar
    Feb 2010
    Chicago, IL
    Hey Ladies & Gents;
    Looking at putting a new sound system in my 00 GTP. Thinking on running Infinity Kappas and a decent amp. Not going to put in subs initially, but I'll put large gauge wire in and whatever else I need should I want to add in the future.
    Anyway, how does one typically wire a GP? Are there any trick routing methods to making it easier to run the power from the hood to the trunk? I also want to run new wiring to the doors from the trunk.
    Thanks,
    Kyle
  2. #2 Re: Audio Wiring Tricks?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    theres a hold in the firewall on the far left of the passengers foot room, run it through there and back under the backseat into the trunk
  3. #3 Re: Audio Wiring Tricks?
    pull those plastic door trims off and lay the wire underneath the carpet.
    Its a PITA to get them back in but its easier to lay the wire that way.
  4. #4 Re: Audio Wiring Tricks?
    Cedar Rapids, IA
    ive done it so many times its automatic lol
  5. #5 Re: Audio Wiring Tricks?
    Cedar Rapids, IA
    to the OP if you want pics i can get some just ask
  6. #6 Re: Audio Wiring Tricks?
    Roseville, Michigan
    My power wire is comeing through a grommet in the center of the fire wall,under the carpet on the pass side, I ran it with the stock car wireing. I removed the pass seats and the rear seats but it was worth the clean install.
  7. #7 Re: Audio Wiring Tricks?
    Thread is two months old...
  1. about car audio
    By tonyplo in forum Audio, Security & Visual Electronics
    Last Post: 10-20-2009, 03:56 PM
  2. Any tips or tricks for GMPP sway bar install?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 09-13-2009, 10:08 PM
  3. Last minute tips/tricks/suggestions?
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-15-2009, 10:15 PM
