Thread: metal lightbulb shield inside light housing? is it needed or not
Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
  1. #41 Re: metal lightbulb shield inside light housing? is it needed or not
    Windsor (ON) Canada
    Quick question... occured WAAAYYYY before I took the metal sheild out.. my left light has always seen about 1/2 times bright than my right... what could be causing this?? is the right on dieing/effected?? its been doing this for a couple months now
  2. #42 Re: metal lightbulb shield inside light housing? is it needed or not
    Feb 2008
    Quote Originally Posted by Colossus View Post
    Could be the bulb going out, or there could be a breakdown in the wiring to that bulb. Grab a volt meter, and check the output at both plugs and see if there is any difference. If no difference, then you most likely have a problem with the bulb.
  3. #43 Re: metal lightbulb shield inside light housing? is it needed or not
    Windsor (ON) Canada
    Right on......thanks
  4. #44 Re: metal lightbulb shield inside light housing? is it needed or not
    Oct 2008
    Calgary, Alberta
    the proper hid is no brighter than stock headlights, but when someone mods headlights to give better sign illumination (removing shields/ 100w bulbs) they are brighter than proper hid (to light up signs I have to use high beam, the hid I use only illuminate the road from cars bumpers down) I do agree that hid bulbs in oem reflectors are a bad thing, but so are 100+ watt bulbs, and driving around with highbeam on in heavy traffic.
  5. #45 Re: metal lightbulb shield inside light housing? is it needed or not
    GT Level Member Joe m's Avatar
    mesa,az
    why would you be driving with highbeams on in traffic? and btw with the shields out the normal lights are still less bright then the highs, and you can still see a difference
  6. #46 Re: metal lightbulb shield inside light housing? is it needed or not
    Quote Originally Posted by 98gtp View Post
    Thats unpossible.
    How can there be more light on the road... if the lightbulbs aren't brighter than "stock headlights"?
    Sorry to say, but HID's are stock on a lot of nicer cars these days, and the SUV's with them on are MUCH more blinding than the standard halogen headlight SUV's.
    I say SUV's because those are the only ones with their headlights high enough to blind even if their high beams are off and their headlights are aligned properly.
    HID headlamp burners produce between 2,800 and 3,500 lumens from between 35 and 38 watts of electrical power, while halogen filament headlamp bulbs produce between 700 and 2,100 lumens from between 40 and 72 watts at 12.8 V.
    From Wiki but i'm sure Sylvania would produce similar numbers.
  7. #47 Re: metal lightbulb shield inside light housing? is it needed or not
    SE Level Member neyel8r's Avatar
    DFW TX
    i hate that sooooooooo much... super blinding-ass bull****! can't even see the road in front of me when they approach & pass by or i'm blinded by them in my rearview mirror... perhaps some don't aim them properly or others don't use the proper housings, but it seems like some SUV folks intentionally aim their bright-ass **** right at eye level!!
    '05 GT - open cone intake, 80w xenons, ceramic harnesses, LED front signals\interiors\reverse lights, tint & stereo soon, the rest stock... for now
  8. #48 Re: metal lightbulb shield inside light housing? is it needed or not
    SE Level Member E90 87SS GTP's Avatar
    NJ
    Haha, glad someone revived this thread. I searched to see if someone removed the diffusers and what resulted, but came up empty. Anyways I bought the cheap ebay housing and the diffuser is held onto by three screws. Basically I had to crush the diffuser inside the housing in order to get it out, the only other way would be to open the headlight housing and attempt to reseal it. Long story short the light output is much brighter and high beams work equally well. Nobody has high beamed me. And honestly the light output is the weakest of all my cars + i'm running silverstars. Yes, the lights are aimed correctly...
  9. #49 Re: metal lightbulb shield inside light housing? is it needed or not
    GT Level Member chickenfried's Avatar
    Feb 2010
    Gilman IA
    hey guys i am going to revive this thread again to release my findings. i took the shield out of my drivers side to do a side by side comparison. standing in front of the car the drivers side looks the exact same as the passenger. really i could not tell any difference in brightness(dims or brights). i took it out on the road and noticed a little difference in visibility in both lows and highs, but nothing to be really excited over. who ever said it was a 2 minute job exagerated by 30 minutes. mine are screwed in and the piece does not slip out(didnt try k.y.) i pryed, twisted and pulled to get it out and needless to say the shield will not go back in my light even if i wanted it to. i will try to have some pics up tmr night and when i change my passenger side i will report again.
    on a side note, matt if you read this... you said earlier that 9007 is not the bulb to use so you make me ask, what is the "right" bulb?
  10. #50 Re: metal lightbulb shield inside light housing? is it needed or not
    Anything that isnt dual filament.
    But you cant change that.
  11. #51 Re: metal lightbulb shield inside light housing? is it needed or not
    GT Level Member Lvgrandprix2003's Avatar
    Cincinnati
    I just got finished doing this a minute ago, Before I even looked on this thread. My car was strange, the lows would be where I wanted them, and the highs would be offset! So I will see how it looks when i head out to work tomorrow morning. And it took me about 5 min to remove them without damaging them.
  12. #52 Re: metal lightbulb shield inside light housing? is it needed or not
    Everything Matt has said is true. Doing this technically makes your lights illegal, Some of you are lucky they don't do Inspections like they do in Europe, They inspect the output of your headlights and how they are positioned, and those of you pull the metal shroud out of the light, you would fail.
    I know the light output sucks on these cars, my Suggestion? Besides a retrofit, I would make a Relay Harness (pretty easy to do), get some High wattage bulbs (80watts or higher, they tend to be made by Hella, don't buy those ebay POS saying they will up the output). I did this on my dad's Caddy, I should have grabbed so pics but they actually did help to make the beam pattern branch out a bit better, it was great but better.
    And just to make it all fair, that is actually legal to do. Doing a Retrofit is technically illegal.
  13. #53 Re: metal lightbulb shield inside light housing? is it needed or not
    Cincinnati
    After driving last night and this morning, the lights are better. Not as dramatic as you would want, but for the price, you can't beat it. I would say this is worth doing for the time and tools involved.
  14. #54 Re: metal lightbulb shield inside light housing? is it needed or not
    Brownsburg
    When I came back from a meet in Chicago a friend was behind me w/ 35w HID on his regal and when he tinted his headlight awhile back forgot one of the diffusers. The light with the one missing was significantly worse as far as glare goes. It wasn't brighter, it just spewed light out EVERYWHERE, pretty irritating behind me and I have 5% tint on the back of the car.
  15. #55 Re: metal lightbulb shield inside light housing? is it needed or not
    Quote Originally Posted by Reefer82 View Post
    this. all this.
    anyone who took that diffuser is dumb. sorry, but you are.
  16. #56 Re: metal lightbulb shield inside light housing? is it needed or not
    and its illegal.
  1. Water/Moisture on Inside of Tail light
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 05-22-2018, 10:11 PM
  2. removing dome light housing
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 01-16-2010, 06:45 PM
  3. Light bulb inside head units
    By sasquatch094 in forum General Tech Discussion
    Last Post: 08-18-2009, 06:25 PM
  4. hole in the intake plenum inside pcv housing??
    By Rick C in forum Introductions/Noob Questions
    Last Post: 02-15-2009, 06:03 PM
  5. hole forming inside of the PCV housing attached to intake plenum.
    By Rick C in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-15-2009, 11:47 AM
