Thread: Some questions about car audio.
Results 1 to 20 of 29
  1. #1 Some questions about car audio.
    Aug 2008
    Pennsylvania
    Okay I have a decient system i would say... well better than sum. I have a 98 grand prix. There are 2 in the front doors ( one on the bottom one toward the top) and two back speakers and all are stock except the ones on the front doors on the bottom.
    If i get a system will i be able to hook up my steering wheel connections with a new deck?
    I was looking at like 300-400 (at most) for a system that is pretty good with a sub.
    The problem is that is my stock system good? or would i benifit with other speakers?
    What kind of subs go with which types of amps like i get the watts and ohms all mixed up when it comes to connecting amps to decks and to subs....Like does a amp that puts out 300 watts push a lot of subs? What is a good size sub? what kind of subs are better square or circle? 1 or two of em? why do they go in the truck is this for safety?
    if anyone isnt tired of reading all of this or getting annoyed by it could you like gimme ideas on good parts for a system?
    I Always Need Help
  2. #2 Re: Some questions about car audio.
    Quote Originally Posted by thenervemann View Post
    If you think its decent then why are you upgrading?
    Not without the proper adapter for that. I know ZZ sells one, check crutchfield for a part number. Others may know on that, I dont.
    Start looking for used things for sale in your local craigs list because this stuff is expensive.
    If you can't answer that, then there probably isn't any point in spending money on a system which you won't appreciate. Save it for something else you want.
    Watt = unit of power
    Amp = Unit of current
    Ohm = unit of resistence
    That'd be good for one 10-12" entry level subwoofer.
    10-12" is more than adequate for most.
    Circle. Squares cibes will flex unevely meaning more distortion than a cone.
    1 or two of em?
    Whatever is cheaper, "looks cooler", uses less trunk space etc. you need an idea of what you're willing to live with.
    Because everyone is too lazy to make them fire into the cabin and because there isn't enough space for a proper sub enclosure anywhere else in most cars.
    Answer above first.
    You must have
    A) budget, which is done.
    B) Goals, unclear
    C) your list of tools, unclear
    D) a limit to how much you're willing to modify your car, very unclear.
    Answer some of the question above first.
  3. #3 Re: Some questions about car audio.
    Quote Originally Posted by schroedes View Post
    a ''good'' system will involve at a minimum, quality subs and speakers,
    Nope.
    quality wiring,
    Nope
    good box,
    Yup
    sound deadener,
    Nope
    and quality amps for the speakers and subs,
    Nope
    at least a $1000 bucks or your wasting your time
    I'd say 400-800 if you're careful how you spend your money.
  4. #4 Re: Some questions about car audio.
    Feb 2009
    Virginia
    Amps = power. Quality = source. Wiring?...go find some lamp cord. It's good copper and probably free at the land fill. Wrap it up to make it look as pretty as needed so you feel better about it and you're done.
    Get some Sony Xplod amps or something rather...matched with a nice deck and you'll be fine. Typical output from "cranked" systems relates to about 16w per speaker and ~100db.
    Audiophile systems are only as expensive as the person wishes them to be.
    Sound deadening? That involves MLV and foam. Mass loaded vinyl will add weight to resonating panels which will then transfer their resonation to lower frequencies. MLV only needs to cover 25% of the center of said vibrating surfaces to remove 95% of the problem.
    You match the MLV with closed cell foam to dampen the noise. Majority of the noise is transferred from the road to tires, through wheel wells, and eventually to the cabin. Fight the source.
    You can have an amazing system for ~$500 if you're a good shopper
    The real research begins when matching speakers with installation goals. Don't skimp on good installation practices and ask people like matt to figure out how to match speakers for said purpose; i.e. music, burps, SPL stuff...etc.
    11 is louder than 10!
  5. #5 Re: Some questions about car audio.
    Feb 2009
    Virginia
    Here's a good link to get you started...
    Basic Guide-read this before posting - DIY Mobile Audio
  6. #6 Re: Some questions about car audio.
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Id buy it one component at a time. start with head unit then replace speakers in car then add amps and subs that way you get quality stuff everytime and your system gets slowly better. just a thought
    silver 2003 Grand Prix GT List is on it's way to be updated
  7. #7 Re: Some questions about car audio.
    Quote Originally Posted by kjohnson View Post
    Or save all your money till you decide what you want to do that way you don't buy something that doesnt suit your needs when you later on figure out what you wanted in the first place.
  8. #8 Re: Some questions about car audio.
    New Jersey
    as long as wire is copper and 14-18AWG in short distances there will be no difference.
    keep runs under 50 feet "easy in a car"
    so yea, lamp cord. I buy 14awg on 1000ft spools from an electronics supply house.
  9. #9 Re: Some questions about car audio.
    Feb 2009
    Virginia
    Quote Originally Posted by MrTube View Post
    *good game*
    If people would actually calculate loads you'll realize that 16awg is probably all you'd need for subwoofer connections and it's more than you need for components. If you want bragging rights or a tougher install then, by all means, buy the biggest and baddest but reality doesn't change due to marketing and snake oil.
  10. #10 Re: Some questions about car audio.
  11. #11 Re: Some questions about car audio.
    lamp wiring from a landfill??? lol, i agree with matt ^, but wiring is important and alot of people skimp on it, best speaker in the world will sound like **** without proper wire
    No.
    All wrong.
    Copper is copper.
    All that matters is the gauge.
    Look up your actual loads and see what you actually need then come back and try and claim different.
    If no one can decide on what criteria you should be looking for or how to install it, then why would you even bother suggesting actual products to buy?
  12. #12 Re: Some questions about car audio.
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    that gets desently loud and has decent sq and is cheap
  13. #13 Re: Some questions about car audio.
    Feb 2009
    Virginia
    Don't get butt hurt Turbo That's just matt's way of saying he cares. Everybody has their choices and a different knowledge base instigates selection criteria. In the end, it would probably benefit the op if you could explain your choices. Then we'd probably converse a bit more
  14. #14 Re: Some questions about car audio.
    That doesnt seem like someone who is asking for SQ but really wants to know what SQ means.
    If this thread is going to be helpful to the OP, the OP needs to post here...
    Otherwise, we're just bickering amongst ourselves.
  15. #15 Re: Some questions about car audio.
    Aug 2008
    Pennsylvania
    Thanks you guys for all your answers... i have another question though, what about getting set of subs and an amp off of craigslist they seem to have a ton of em for sale for good prices
    I Always Need Help
  16. #16 Re: Some questions about car audio.
    Good idea, just post the links to the ones in your price range and we'll let you know if its worth it or not.
  17. #17 Re: Some questions about car audio.
    Donating Users JESSEGOTTA GP GT's Avatar
    NC
    To tell you the truth, if your gonna get a sub/s, you'll probly want to upgrade the door speakers and rear deck lid speakers to handle the power from a new stereo, and you want them to be clear and crisp, unless you like to roll around and hear just bass and no music. I made that mistake once buy putting all my money into subs and an amp, and keeping the stock speakers, if I turned it up to hear the music with the bass, it sounded like an 80 year old man sh!tting, or I could roll around and only hear the bass, which was annoying as hell. It's up to you, but I would reccomend getting decent speakers and a stereo, then saving up and getting decent subs.
    New project: 2000 Red GTP.
  18. #18 Re: Some questions about car audio.
    GTX Level Member real diehl's Avatar
    Salina, KS
    Single 12. Sealed box. Around 400-500 watts peak mono block amp.
    This is considering you buy a good sub...
    some of my favorites are MTX, Hertz, Diamond Audio, and RE.
    The box type depends on what music you listen to. If you like big bass and hip-hop, get a ported box. If you like rock/metal and a more theater-like sound, get a sealed box. Stay away from bandpass boxes, no matter how "cool" people think they look.
    signature removed for inappropriate content.
    -bio
  19. #19 Re: Some questions about car audio.
    Ummmmmmmm bandpass is the only way to get the bass in the cabin while using a large sub.
    In fact, bandpass is the ideal solution for those looking for high clean SPL and not rattling their trunk to death.
  20. #20 Re: Some questions about car audio.
    MO
    who said sony amps? Sony is entirely JUNK
    <brandonl2000> LMAO D!!
  1. audio
    By 95granprix in forum Introductions/Noob Questions
    Last Post: 11-24-2009, 01:00 AM
  2. about car audio
    By tonyplo in forum Audio, Security & Visual Electronics
    Last Post: 10-20-2009, 03:56 PM
  3. Help car audio
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2009, 05:27 PM
