Thread: Getting new subs want opinons.
Page 2 of 13 FirstFirst 123412 ... LastLast
Results 21 to 40 of 259
  1. #1 Re: Getting new subs want opinons.
    Feb 2009
    Virginia
    a/d/s/ 312rs?
    I want a pair
    11 is louder than 10!
  2. #2 Re: Getting new subs want opinons.
    Buy a pair of BTL's yet?
    Get the HiXmax coils and choose daily, not SPL and it'll sound pretty damn good.
  3. #3 Re: Getting new subs want opinons.
    swift current,sask.
    I still am debating on what I want to do. A w7, or a single 12 BTL Which do figure is better?
  4. #4 Re: Getting new subs want opinons.
    New Jersey
    BLT's? Na I dont like lettuce or tomato. I'm more of a Bacon and Egg kind of guy...
  5. #5 Re: Getting new subs want opinons.
    Fixed...
  6. #6 Re: Getting new subs want opinons.
    what can you get the W7 for and would you go for the 12" W7?
  7. #7 Re: Getting new subs want opinons.
    swift current,sask.
    Not too sure yet, looks to be over $500 anywhere and yes it would be a 12w7.
  8. #8 Re: Getting new subs want opinons.
    I'm doing up some graphs right now to show the difference..
  9. #9 Re: Getting new subs want opinons.
    All of these are shown with a low pass filter at 12 dB/octave centred at 80 Hz.
    Ported:
    And sealed:
  10. #10 Re: Getting new subs want opinons.
    I went with the Q after seeing just how much of an SPL driver the BTL really is as well as your other choice of the W7 which is more of a SQ woofer.
    The cost of the Q is 244 shipped i believe, unless they started charging for shipping, not sure.
  11. #11 Re: Getting new subs want opinons.
    swift current,sask.
    Well in that case the Q is a better choice then, what if I went with 2 Q10's?
  12. #12 Re: Getting new subs want opinons.
    I'd have to do that over again.
    Doesn't take much time.
    Want to go sealed or ported?
    Do you like massive bass in your face or for it to sound roughly "right"?
    Whats the maximum space you're willing to give up in your trunk?
  13. #13 Re: Getting new subs want opinons.
    swift current,sask.
    -I would go sealed
    -I would like it to sound good but get loud(if you get what i mean)
    -as much as it takes, it's more my summer car than anything. Thanks so much for your help!!
  14. #14 Re: Getting new subs want opinons.
    Ya not a problem.
    The question is then, why are you limiting yourself to a pair of tens if you're going sealed? Why not take advantage of the size of the trunk and go for a pair of sealed 12's?
    Larger the cone, the less distance it has to move to produce the same sound level. The more it moves, the more distortion there is. Therefore the largest driver you can get away with is the best choice. Also more efficient with the power you feed them so you get more sound for your dollar and watt.
  15. #15 Re: Getting new subs want opinons.
    New Jersey
    Just keep in mind, anything over a 12" and cone breakup goes up substantially.
    Tho, I still loved the sound the EV 18's I had produced. There was just something effortless about them.
  16. #16 Re: Getting new subs want opinons.
    swift current,sask.
    Quote Originally Posted by MrTube View Post
    So What should i do then?? Still open to suggestions.
  17. #17 Re: Getting new subs want opinons.
    New Jersey
    two 12's like matt said. In a quality made enclosure made to the specs to match the woofers.
  18. #18 Re: Getting new subs want opinons.
    Umm, if you're crossing any higher than 80 Hz you're doing it wrong.
  19. #19 Re: Getting new subs want opinons.
    New Jersey
    Says you
    besides,
    cone breakup happens at all frequencies. a 15" driver will have plenty at 30Hz.
  20. #20 Re: Getting new subs want opinons.
    Says you
    besides,
    cone breakup is an issue with midrange speakers... in the area of 3-10 KHz.
    Subs are directional above 100-150 Hz. So if you're crossing over at 80 Hz, thats dangerously close to too high.
    40-50 Hz is a much better spot which gives you much more freedom in your sub location.
    Heres a better question, how does a 15" sub have breakup at 30 Hz?
    At 30 Hz, the entire cone is moving a large distance and all of the second and third harmonics are due to suspension and motor non-linearities, not the cone...
  1. changing over to a new oil need opinons please
    Last Post: 06-01-2009, 12:46 AM
  2. your opinons
    By DDPeppa in forum Visual/Body Modifications
    Last Post: 04-25-2009, 07:35 PM
  3. Just some opinons for hand guns
    Last Post: 02-16-2009, 05:06 PM
  4. Opinons on this trade?
    By GoingPontiac in forum Off Topic Discussion
    Last Post: 02-03-2008, 08:21 PM
