Thread: 04 Grand Prix Radio Install
Results 1 to 10 of 10
  1. #1 04 Grand Prix Radio Install
    Nov 2008
    ohio
    I have an 04 GTP without onstar or bose, what do i need to install an aftermarket radio. I know there are ones with chime and stuff, but I dont need that right?
    04 Grand Prix GTP (Wizaired, 3 inch downpipe)
  2. #2 Re: 04 Grand Prix Radio Install
    Nov 2008
    ohio
    i have just the basic harness and i wired it up but i need a place to tap into the RAP (retained accessory power)..
    Where can i tap into RAP?
  3. #3 Re: 04 Grand Prix Radio Install
    Nov 2008
    ohio
    come on i know someone knows what to do!!!!
  4. #4 Re: 04 Grand Prix Radio Install
    Get a wiring kit that hooks into the factory harness. That will give you RAP.
    But seeing as you've already done that, I can't see why you don't already have RAP.
  5. #5 Re: 04 Grand Prix Radio Install
    Nov 2008
    ohio
    well i figured it out. I ran a wire to the fuse box and taped into the RAP relay. And the wiring harnesses on the 04+ dont have RAP built in. The red wire is there but there is no power. The wiring kit even said so, and gave a separate wire to tap into accessory power or RAP
  6. #6 Re: 04 Grand Prix Radio Install
    Glad you figured it out, good to know.
  7. #7 Re: 04 Grand Prix Radio Install
    Nov 2008
    ohio
    ya it sucks, the DIC doesn't keep the date anymore
  8. #8 Re: 04 Grand Prix Radio Install
    Feb 2009
    Virginia
    Long as I have tunes I don't care about the time of day, week, or month Btw, if you look hard enough you can find wiring harness + RAP for ~$30. Talk to local audio shops. If they're any good they won't sell you that $100 p.o.s. GMOS-01
    For others reading this thread, simply running your wiring harness "12v always on"(should be yellow) through a toggle switch to the radios 12v turn-on is the simplest way to bypass RAP. However, the radio responds to a switch now and you MAY or MAY NOT forget to turn it off before leaving the car ;P
    11 is louder than 10!
  9. #9 Re: 04 Grand Prix Radio Install
    Nov 2008
    ohio
    I looked, but i never found one for $30
  10. #10 Re: 04 Grand Prix Radio Install
    Feb 2009
    Virginia
    They're tough to find. They have a built in speaker for chimes instead of the LOC that connects to the H/U speaker outs. It doesn't sound as high dollar as the factory H/U rap that outputs through your speakers but I think it's perfect!
  1. In dash screen/radio for 2004 Grand Prix!
    By adooprajh in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2009, 04:05 PM
  2. 07 Grand Prix - Rear defroster messes up radio
    By thevolkp in forum General Tech Discussion
    Last Post: 10-23-2009, 10:28 AM
  3. 2006 Grand Prix CB Radio Install
    By novacoke in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2009, 10:01 AM
  4. 01 grand prix gt radio mod
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2009, 12:09 PM
  5. 2002 grand prix radio wiring
    By NEONNIGHT34609 in forum Audio, Security & Visual Electronics
    Last Post: 03-23-2009, 07:37 PM
