Thread: General consensus on keeping steering wheel controls? Easy?/hard/worth the trouble?
Results 1 to 8 of 8
jeighty3 General consensus on keeping... 05-04-2012, 03:49 PM
KeithGTP03 Re: General consensus on... 05-04-2012, 06:24 PM
thenose Go to www.crutchfield.com and... 05-04-2012, 06:30 PM
Iced Iridium Re: General consensus on... 05-04-2012, 06:31 PM
Bronco Boy Re: General consensus on... 05-05-2012, 11:05 AM
bigboibbp Re: General consensus on... 05-06-2012, 09:42 AM
Bronco Boy Re: General consensus on... 05-06-2012, 12:41 PM
The Guz Re: General consensus on... 05-05-2012, 07:23 PM
  1. #1 General consensus on keeping steering wheel controls? Easy?/hard/worth the trouble?
    Dec 2011
    ca
    I have an '02 grand prix gtp coupe with bose and onstar. i also have a pioneer deck w/remote that i want to install, however i'd like to keep everything as functional as possible, and having a bunch of dead buttons on my steering wheel doesn't seem too appealing.
    What do i need to make my deck work? i'm assuming some sort of adapter is required to work with the bose, and a second adaptor to use the factory wheel buttons with my new deck. What is recommended? what works, what doesn't? thanks
  2. #2 Re: General consensus on keeping steering wheel controls? Easy?/hard/worth the troubl
    Houston
    There are a couple routes you can go. There's a universal adapter which kinda sucks because you have to mount the IR sensor in view of your radios IR sensor. You can use this with any radio that has a remote IR sensor in it. (I.E. it came with a remote or has the option for one)
    *Universal Steering Wheel Control By Pac Swix (Pac Adapter) - PAC - swix
    Or you can go with a radio specific adapter that doesnt need the IR sensor. You can only use this if your radio has a steering wheel interface jack on the back of the radio.
    * Pac Swi-Ps Steering Wheel Interface (Pioneer, Jensen, Dual, Visteon, Advent And Sony) - PAC - SWI-PS
    It will still need to be programmed which can be a pain in the ass your first time. If you mess up you have to start all over. But after a few tries, you'll have that shÃ*t down. Just follow the instructions included.
    SE Level Member thenose's Avatar
    Apr 2012
    Athol, Massachusetts
    Go to www.crutchfield.com and check the accessories for the specific Pioneer you have. A lot of better head units have optional steering wheel adapters that are built for that head unit.
  4. #4 Re: General consensus on keeping steering wheel controls? Easy?/hard/worth the troubl
    SE Level Member Iced Iridium's Avatar
    Dec 2011
    Daytona Beach, Florida, United States
    You can use the normal aftermarket stereo kits from METRA or similar for the brackets and the wiring
    For the steering wheel interface you'll need a PAC Audio SWI-PS or an AXXESS ASWC. Same installation for both, and both can have the buttons custom mapped, but the AXXESS already has a good configuration built in and it auto-detects.
    For audio you can go one of two routes.
    1. Wire from the speaker output of the HU as you would with a normal non-amplified system. This is not the best solution as you would never want to turn the volume past around 1/2 unless you feel like frying the amplifier.
    2. Wire the line-out from the HU (if it's 4+ channel line-out) to the same wire as mentioned before. This is better because the BOSE amplifier relies on low-level input from the factory head unit.
    IIRC for On-Star, you need a GMOS adapter, but having never messed with a GP with On-Star I'm not 100% sure.
    Read the Audio Knowledge Sticky for more info!!! That's why it's there. Good luck with the project!
  5. #5 Re: General consensus on keeping steering wheel controls? Easy?/hard/worth the troubl
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by jeighty3 View Post
    You need a Metra 70-1858 wiring adapter and an Axxes ASWC module for the wheel controls.....
    The Axxes module took about a minute to self program, and the wheel controls work as they did with the stock radio. My JVC remote has yet to come out of the center console.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: General consensus on keeping steering wheel controls? Easy?/hard/worth the troubl
    SE Level Member bigboibbp's Avatar
    Chicago
    Quote Originally Posted by Bronco Boy View Post
    Ant way u can help me out with this. Got my head unit in but was a bit intimidated by the metra adaptor.
  7. #7 Re: General consensus on keeping steering wheel controls? Easy?/hard/worth the troubl
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by bigboibbp View Post
    What do you need help with? You connect the wires from the Metra adapter to the wires from the radio harness, then plug them in.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: General consensus on keeping steering wheel controls? Easy?/hard/worth the troubl
    Dec 2008
    Lawndale, CA
    What model headunit is that pioneer? That will let you know what steering wheel adapter (PAC vs Axxess).
  1. Steering Wheel Controls
    By ljmonnin12 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 04:37 PM
  2. Steering Wheel Controls
    Last Post: 11-17-2010, 04:25 PM
  3. Steering Wheel Controls....
    By RedGTDT in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2010, 09:59 PM
  4. steering wheel controls?
    By CrazyCanuck in forum Audio, Security & Visual Electronics
    Last Post: 02-16-2009, 12:42 PM
  5. steering wheel controls
    By 52 picup in forum General Tech Discussion
    Last Post: 10-22-2008, 10:44 PM
