Thread: big install
Results 1 to 10 of 10
  1. #1 big install
    Joliet, IL
    hey guys im putting a pioneer double din 7 inch lcd with gps, hd radio, bluetooth the whole shebang.....ive done lots of HU installs in 04+gp's but this will be my first dvd/gps unit.....just wanna know if install supplies are the same....im assuming i dont need a dash kit anymore? what about wiring harness' and i will have a brain to mount also.....what sensors or vehicle wires to i need to tap into as far as the brain goes? anyhelp is greatly appreciated thanks...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: big install
    Outer Space
    All supplies should be the same. However, you may want to tap into a dimmer source. I am unsure on the double DIN stuff. I always go to crutchfield.com and see what they say when you plug your car info in.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: big install
    May 2008
    staten island,NY
    double din wont fit in the 97-03, these cars are din and a half or 1.5din...thanks a lot GM
  4. #4 Re: big install
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    If you are putting it in you 00, you can do it, but it takes some fab work. I have not done it, but you can search it. Someone just put up some pics of their install
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  5. #5 Re: big install
    And you got me all excited with "big install"...
    It'll hook up just like any other deck but you'll need to mod your dash to get it to fit.
    Go to the junker or PM fish and get a new dash bezel so if yours becomes fubar'd, you have a spare.
    Quote Originally Posted by Lawngoose View Post
    The factory harness is pre-wired for a dimmer, just gotta use the correct harness and you'll be okay.
  6. #6 Re: big install
    Dec 2008
    chicago,illinois
    Make sure you post pics i might take this mod up next
    going low on 20"
  7. #7 Re: big install
    Joliet, IL
    its going in an 04+ i know its no biggie i just wanna know what new stuff ill run into with a double din/gps/dvd screen unit......
    00 Silvermist GTP
  8. #8 Re: big install
    GT Level Member gpgt04's Avatar
    MA
    if they want to keep the onstar and all of the door chimes there is a special wiring harness that needs to be used. its made by metra. i forget the model number. it would be on crutchfield
  9. #9 Re: big install
    May 2008
    staten island,NY
    ohhhh an 04 well that puts a whole different day job on things, good luck with the install
  10. #10 Re: big install
    Joliet, IL
    the car doesnt have onstar
    00 Silvermist GTP
  1. 04+ HUD Install
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-06-2012, 02:25 PM
  2. Do I need a cam kit to install a VS cam
    By ncccgolf5 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 02:51 AM
  3. L36 LIM Install
    By 01gtspecial in forum General Tech Discussion
    Last Post: 07-08-2009, 10:29 AM
  4. please help!!! cai install
    By BIGTMANE in forum General Tech Discussion
    Last Post: 06-05-2009, 05:27 PM
  5. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
